Question about GE WCVH6800J 27" Front-Load Washer with 3.5 cu. ft. Capacity, 26 Wash Cycles, HydroWash System, 1,100 RPM Spin Speed and ADA Compliant
GE front load washer schematic
How to change belt
    Top Expert:
  • GE Master
  • 9,472 Answers
Remove the rear access panel.
Posted on Dec 03, 2012
philbran
  • 242 Answers
SOURCE: Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Posted on Jan 07, 2009
dutchman05
  • 487 Answers
SOURCE: ge front load washer leaks from bottom
full display
And for the part numbers look here
Have fun with it and please rate me on this site
Posted on Apr 20, 2008
  • 35 Answers
SOURCE: mildew in ge front load washer
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
Posted on Jun 05, 2009
SOURCE: Front load GE washer
you just push the delay button once and the light will go off.
Posted on Jul 18, 2009
  • 1531 Answers
SOURCE: GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Posted on Sep 17, 2009
How can i order a rubber seal for my ge front loader washer wbvh6240fww
I found the best site was Sears parts site. They usually have the schematics so you can order the right part and is you may need another.
Jul 02, 2014 | GE Energy Star WCVH6260F Front Load Washer
Ge washer will only spin with no load
Your washer has a 2 speed clutchless motor. If it spins with no load I would first look at the belt. You can remove the front of your washer by inserting a putty knife about 4" on the right and left top of the front panel and push in. This should release the front panel so you can see what is going on. If the belt is worn replace.
Apr 17, 2013 | GE WBSR3140DW Top Load Washer
How to change belt on whirlpool ultimate care plus washing machine
Top loader? Turn machine up so you can see underneath, remove access panel, belt right in front of you. Fits over motor spindle and base of agitator spider
May 19, 2012 | GE WBSR3140DW Top Load Washer
My daughters GE same model washer will not agitate. Stop agitating after just a few months after being purchased. I believe this is a trait from this type of washer. Perhaps GE needs to recall them all...
Premature failure usually is a reuslt of overloading and/or not enough water. So, there is a rubber drive component that fails and some models have agitator pawls, or dogs that fail. Both are fairly easy to change, and not pricey, except for labor..
Feb 07, 2011 | GE WBSR3140DW Top Load Washer
How do i remove the front to check or replace belt
If you need an owner's manual see this site.
http://genet.geappliances.com/DocSearch/Dispatcher
Unless GE has changed in recent years the motor and transmission can be serviced from the rear of the washer. GE engineering did not have a front service panel when I serviced them. Belts usually last a long time, look for a bound water pump or other problems.
Jul 10, 2010 | GE WBSE2090A Top Load Washer
Changed main belt in machine and need to know
check earth wire is on motor, heater element and if metal tub fitted then this will be earthed aswell
Feb 16, 2010 | Electrolux AWW1017 Front Load Washer /...
Front loading GE washer making noise when the drum turns. sounds like a belt but I don't have the manual and don't know how to get the top off.
there should be two screwws in the door jam on the front panel, they hold the top down
once you remove those slide the top backwards then lift up
let me know if its the belt
Oct 19, 2009 | GE WSXH208A Front Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
Ge front load washer leaks from bottom
full display
Apr 19, 2008 | GE WSXH208A Front Load Washer
GE WCVH6800J 27" Front-Load Washer with 3.5 cu. ft. Capacity, 26 Wash Cycles, HydroWash System, 1,100 RPM Spin Speed and ADA Compliant Logo
60 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
