Question about Disney Cars Umbrella Stroller
Disney cars umbrella stroller front wheels
The front wheels swivel and get stuck sideways, the stroller wont move forward - absolute pain to use - is there a way to fix this?
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
My front wheel is sticking on my buzz. It gets
yes give it a good sqwert of WD40 and spin it round by hand till its free again it sounds like it may also be a bent shaft have you hit any big bumps? or has the baby put on a lot of wate?
Oct 24, 2009 | Quinny Buzz Three Wheel Stroller
Front wheels keep getting stuck in swivel postion
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Feb 15, 2009 | Valco Runabout Tri Mode Jogger
Hauk infinity reversible pushchair, swivel wheels won't swivel
Removed the wheels and gave a little spray of WD40 lubricant, the wheels swivel perfectly now - very easy!
Aug 29, 2008 | Hauck I'coo Pico 4 Standard Stroller
Front wheel getting stuck
i have the same problem, was wondering if you can buy the double one for the front. Have used wd40 on wheel and this has helped a little.
Jul 29, 2008 | Quinny Buzz Jogger
Front Wheels
Did you check the levers on the front wheels to make sure the front brake isn't on?
May 17, 2008 | Kolcraft Umbrella 36010 Stroller
Funny front wheels
remove the total front housing by pressing the 2 plastic buttons on the silver bar that holds the wheels in place. then get a small screwdriver and put in in the small hole on the black plastic part of the wheel there is a button in there but you will need to look in the hole to find it then push button with screwdriver and pull off the 2 wheels. clean and use wd40 not oil. this should fix problem if not phone dorel (they sell/own quinny) in the UK 00442082360707
May 10, 2008 | Quinny Buzz Jogger
Front wheels swivel and get stuck on each other
This is happening to my stroller and it turns out that the frame is bent. I have been unable to find a certified technician who is willing to fix it. I guess I can offer it for parts to someone.
Sep 24, 2007 | Valco Twin Runabout ATS Jogger
Front wheel problem with Peg Perego Aria single stroller
You need to regularly lubricate the wheels...Just get some WD-40 with the little straw attachment & spray into where the wheel meets the frame...Make sure you lubricate the wheels regularly...I had the same problem & call Peg toll free - that was the answer & it fixed my problem too!!
Feb 12, 2007 | Peg Perego Aria MT Rubino Standard...
Disney Cars Umbrella Stroller Logo
293 people viewed this question
Top Disney Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Disney Baby Gear Expert? Answer questions, earn points and help others
