The pulley on my top loading washing machine i think is froze up how can i tell?
Washing machine was spinning out was making a horrible clanging banging noise. When i checked to see if the belt broke the motor was still running but the belt was not
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 03, 2012
  • 4 Answers
SOURCE: indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
Posted on Dec 29, 2007
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Posted on Oct 29, 2008
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
SOURCE: Washing machine making loud noise when agitating/spinning
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Posted on Jun 30, 2009
  • 235 Answers
SOURCE: makes a horrible noise when spinning out
Changing the belt should help.
Posted on Jul 02, 2009
Xqb90-701clps
Some where at the bottom there is springs that can be broken or out of position, or the jockey pulley might need replacment
May 10, 2017 | Washing Machines
My washing machine will not spin. It sounds like its off track or off gear or something. It just makes a horribly loud noise.
Most important in such a case is a perfect observation. So remove power and look for the motor drive. Manually check for the drive turning the pulley of the motor , check if there is any jamming or mechanical fault in the drive shaft , if so you will need to reset - over haul - this section.
Feb 19, 2011 | Frigidaire FEX831CS Top Load Stacked...
My eurotech washer is making a horrible noise during the spin cycle...it wont drain or spin what do i do
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 28, 2010 | EuroTech EWF172 Front Load Washer
Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
May 18, 2009 | Kenmore 22422 Top Load Washer
My washing machine wont spin anymore
my washing machine makes a horrible noise while washing and retains water after spinning. what help can i get?
Nov 24, 2008 | Roper RAS6233KQ Top Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Squeak upon spinning
Hi, I wanted to comment on this because I have the Majestic MJ9200 Washing machine front load for the RV. I am having the exact same problem and I cannot use my machine at this time. This is NOT an unbalanced load problem. An unbalanced load will cause a loud banging noise because the drum is off balance. There is something wrong inside your machine. Mine never had this problem before either and an unbalanced load does not cause this horrible screech while on the spin cycle. My machine like yours made the noise only on certain spin speeds, high 1500 rpm spin the first time and when I adjusted the spin cycle just to see what happened it stopped making that horrible noise. I washed another load and it began that same screetch while spinning and it was then in all RPM ratios available on my model.
My husband took the top off the machine and could not see anything evident but when looking into the front of the machine we could tell that is seems the interior drum is much looser in the washing machine than in the dryer. There are two drums on the front load. A larger outer drum and a smaller inner drum. The inner drum is what is looser in our machine and the noise is a very loud screetch while spinning the water out of the clothes.
Is your machine under any kind of warranty? Mine is not and I am waiting to get it fixed.
Good luck on getting yours fixed and perhaps we can both help each other out on this one although we have different brands of machines...
May 25, 2006 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
