Question about Kohler Command Pro 7-HP 208cc Engine - PA-CH270-3011
7hp 208cc engine wont start - Kohler Command Pro 7-HP 208cc Engine - PA-CH270-3011
Engine kicks back when pull starting why?
not pulling the cord hard enough or the ignition timing is out.
Sep 29, 2016 | Honda Cars & Trucks
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
208cc to hp
208 cc = 8 to 9 Gross Torque = 5.5 to 6 hp
The following article has a fairly good explanation of how to convert but as the writers writes there a lot other variables that are not account for the conversion.
cc to torque to hp Conversion Update
Oct 16, 2014 | MTD PRODUCTS INC Troy-Bilt Bronco...
Won't start
it might be broken so you should go to the shop with it and complain
Mar 31, 2014 | Troy bilt Super Bronco Tiller 208cc
Won't start or turnover
see this was up awhile
so you cant get engine to move at all?
be sure no ice is blocking from moving (move to warm place)
then try
is there oil in it ? if not its set up rebuild or replace
Mar 02, 2014 | Yard Machines 26" 208cc Two Stage Snow...
208cc manual
engine name please but suspect a dirty carb, bad fuel or both
Dec 15, 2013 | Garden
I disassembled a 26" craftsman with a 208cc engine. the crankshaft had a clear timing dimple and the cam had a 1/8" hole near to teeth. i assume that was the cam shaft timing mark... machine wont start.
You are correct about the timing marks. There should be one on one, and two on the other. Is unit an OHV or an L head? Make sure valves are closed and piston is in TDC when lining up and you should be good to go.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Oct 07, 2013 | Craftsman Snow Blower 26 In. 208CC...
Engine surges
sounds like a carb problem if new bring it back to the store
May 05, 2012 | Husqvarna DRT900 960930011 17 Rear Tine...
Can my eb5000 generator run an electric 7hp compressor
7 horsepower is approx 5150 Watts so the compressor would be taking this power while running. On startup however the compressor can take a surge of upto 3 or 4 times this power so the generator wouldn't be able to supply this demand . In any case it's not advisable to run a compressor off a generator unless the generator is high powered, 20KVA or greater for 7hp.
Mar 31, 2011 | Honda Mmd 5000 Watt Generator W/ Engine...
I AM REPAIRING A SNAPPER COMET 30 B/S 7HP RIDING MOWER: (APX. 1966-1969) 1) TIRE PRESSURE? FRONT-410/350-4, REAR-16 X 6.50-8 2) WHICH FRONT BELT PULLEY DO I LOOSEN TO ADJUST OR REPLACE BELT? 3) REAR AXLE...
Chances are you wont get a manual, just lube it up.tires probably 12 to 15 lbs .the belt is mecanicly tensioned so there is no adjustment. Check the idler pully tensoner and ingage lever for proper travel and tention
Jun 03, 2010 | Briggs & Stratton Garden
Kohler Command Pro 7-HP 208cc Engine - PA-CH270-3011 Logo
Top Kohler Garden Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Bade
ray012965
Are you a Kohler Garden Expert? Answer questions, earn points and help others
