Question about Maxent Televison & Video
How to reset a maxent Model # P58H10NJA
TURNS OFF BY IT'S SELF IN SATELITE MODE NOT IN VIDEO MODE
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: Maxent MX42VM10 just turns on for a second and goes to standby
You have a two part problem here 1 is a bad capacitor in the unit witch is preventing startup another another would be your decoder board witch is causing those flashes on the screen just before it remits back to standby. My professional advice is simple take it in get a estimate on it if it cost you more then $200 to fix it then you might want to get a repair manual and do it yourself or find a low cost tech that knows this stuff. Otherwise you will need to search for its replacment, let me tell you plasmas are not going to be servicable after july 2011 so get it fixed while you can or find a good home for it.
Posted on Nov 11, 2009
alpug
  • 1961 Answers
SOURCE: I have a Maxent MX-58HPT51
Try resoldering the parts at the power supply section and check also connectors make sure that there are no loose connectors.press down fuses make sure it have contact on the board If you have a multimeter measure the continuity of the power cord replace the cord.if it has an internal cut.
Try this steps first and let me hear how it goes...good luck!
Posted on Apr 24, 2011
Sherwood audio/video receiver d-6105 turns its self of, strait away, and were is the reset button.
Without the make and model, we're unlikely to be able to tell you if there is a reset button.
If there's a circuit problem inside, though, what you will get is the same as you describe, turning itself off immediately.
Jun 04, 2015 | Audio Players & Recorders
Maxent mx-26x3 video issue
The tv probably does'nt have a fast enough refresh rate to work with games properly. It should be in the manual for the tv, the lower the number the better. I think it's 12 milliseconds on that tv. Have a look here:Response Rates.
Apr 15, 2012 | Maxent MX-26X3 Television
Using satelite speakers on arcam avr100
Depending on the type of satelite speakers, Bose for example used on their own would be damaged, if your satelite plugs into a sub speaker they are protected by circuitry that controls output level when tied into the whole system, so using them on their own is not a good idea.
Mar 30, 2012 | Arcam AVR-100 Receiver
It turns on and comes onto a report problem so i send it but sometimes a report problem doesn't come up nether the less either way it starts for about 7 seconds then just freezes won't let me move...
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
Maxnet mx-26x3 tv toconnect toan HDMI input
Maxent ,mx 26 x3 turns on for 5sc.( all white) then picture flickers and screen goes black.. green light on throughout..none of button on the remote or the tv will work expect the power .i wonder is their a way to reset the tv?
Jun 10, 2011 | Maxent MX-26X3 Television
I have a 42" Maxent
A cable expansion kit box on which every connectable cable is directed towards achived the process. For example, an exampansion cable box convertor allows for every household media devices, VCRs, DVD players, DVR recorders to be connected. Thereafter the convertor box splits the signals to be transmited to the TV set. The TV require a convertor box kit, and high coaxible cable to distribute signals to the TV. consult techncial experts, examples are Cable TV, Disk network, satelite Tv installation experts. Goodluck
Jan 09, 2011 | Maxent Televison & Video
Nov 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Another question about maxent plasma monitor
Yes problem is repairable sounds like the mainboard (video) needs replacement because the rgb is part of this board along with the rest of your inputs this should fix your problem. There are some models where rgb is seperate but not many I will need the model number of your Maxent to be of further help.
Sep 09, 2008 | Televison & Video
Maxent tv remote control code
Hi guys i have Maxent 27 inches LCD and a satelite box i used the salelite remote for my TV The code is 242 Try that and get back to me.
Yourbello
Mar 04, 2008 | Televison & Video
The TV does not respond to the remote control nor the buttons in the front panel
Sounds like power supply switch needs to be changed to normal setting. If you are comfortable with electronics i will talk you through it if not you will need a tech or back to cosco it goes if you have a warranty.
Oct 10, 2007 | Maxent MX-50X1 50 in. Plasma Television
Televison & Video Logo
75 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
