Question about Dryers
Trying to remove front panel on lg DLEX5170 dryer
duby1990
  • 367 Answers
SOURCE: removing front panel
The first thing to do is to remove the plastic plug on the lower left front corner of the dryer. it is just a small square plastic piece. This way you can see if the ignitor is glowing red. But to answer your question, You remove the 2 screws underneth the lint filter. Then the top will just pop up with a screwdriver. Then there is 2 5/16 screws holding the front on. (this is for the most common kenmore. If this sounds all wrong i will tell how the other model comes upart.
Posted on Nov 20, 2008
MNTECH
  • 1543 Answers
SOURCE: LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Posted on Jan 03, 2009
Testimonial: "YOU HIT THE NAIL ON THE HEAD WITH THIS SOLUTION. THANKS"
SOURCE: Whirlpool dryer front panel
I located a video on youtube.com free of charge. I removed the lint screen, and removed the two screws located in the lint screen housing. Then I pryed the top off near the front of the dryer, which has two clips. Then I remove the two screws locate on the top of the front panel, but they are located on the inside. I removed the door lid swich by removing the two screws. Lastly, I pulled the front panel outward and pulled up lightly. The front panel was off. The issue I had was the dryer would heat up and then got cool after five minutes. The solution was to replace the coils. Important point is that the coils ohm readings were within specifications, but I did located information on the web that indicated this was a potential solution to the issue, and I replaced the coils even though the resistances were within specification. Total cost $22.95 plus tax.
Posted on Mar 25, 2009
vickygomar
  • 460 Answers
SOURCE: How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
Posted on May 21, 2009
MNTECH
  • 1543 Answers
SOURCE: How do I remove the front panel of my front
Open door. Remove phillips head screws at 5 and 7 O'Clock positions. Close door. Use putty knife to push in clips (2) relaeasing top. (located in seam where top meets front panel) Swing top back. Remove two phillips head screws at top of front panel. Unplug light and door switch. Tilt front panel forward and lift off bottom tabs.
Posted on Sep 25, 2010
Need to remove front panel of dle0442w to get to heat limit switch
unplug the dryer,remove the top panel,remove the control panel,usually a couple of screws on the top right and left side,when you get the control panel off there are like 4 screws on the top front panel then open the door and remove 2 more screws,disconnect door switch.go here this will help you out i'm trying to go by memory and it's harder to remember how to do it,when i'm in front of it i can pull it apart no problem but this should help you out.
http://www.youtube.com/watch?v=RvbJn61d9hQ
Nov 08, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
I changed orfice on LG DLEX5170 to lp. Are there any other adjustments
you have to adjust the white plastic piece on the valve as well. then you have done
Feb 15, 2013 | LG SteamDryer Series DLEX5170W 27...
How to remove the front panel of my lg dryer
  • Hey Nicholas Coccovizzo
    Unplug the dryer's 3-prong electrical cord from the power outlet.
  • Pull the dryer away from the wall and turn to one side to access the back of the appliance.
  • Remove the screws at the top of the dryer on the back panel.
  • Push the cover of the dryer from the front toward the back to disengage it from the cabinet, then lift the front of the cover up a few inches and toward the back at an angle.
  • Remove the two screws inside the front corners that attach the cover to the control panel. this will disconnect the cover from the front control panel.
  • Unplug the control panel from the wire plugs connected to the knobs and buttons. Set aside the control panel
  • Remove the two screws that were hidden underneath the control panel. These screws hold the top of the front cabinet in place.
  • Open the dryer door in the front of the appliance and remove the screws just below the slot for the lint screen, keeping one hand braced against the front of the cabinet to prevent it from falling forward. Removing these screws will detach the front cabinet from the sides, exposing the motor, dryer drum, belts and the blower for circulating hot air
    Good Luck!
  • Jul 29, 2012 | LG Dryers
    How do I get the front panel off of the LG dryer? I have unscrewed the actual door and screws around the drawer, I am trying to vaccum out the lent under behind the front panel piece.
    remove the top panel screws on the back of the unit first,then the control panel in front,then the lower panel along with the front cover with the door
    Nov 18, 2010 | LG DLE5955 Dryer
    How do I remove the front panel of my front loading LG dryer
    Sep 25, 2010 | LG DLG5988 Gas Dryer
    How to disassemble LG steam dryer
    You can start by removing three screws on the lid of the dryer, slide the dryer lid off. Then if you need to remove the front, you'll need to remove steam-dispenser tray, and remove the screws there, and then on the other side of the control panel. Then once you remove the control panel assembly, the front of the machine has 4-5 more screws to remove. you'll need to disconnect the door switch, before removing the front cover of the machine, sometimes this is very firmly in place, be careful.
    Mar 24, 2010 | LG SteamDryer 7.3 Cu. Ft. Extra-Large...
    Jan 03, 2009 | LG DLG5932W Gas Dryer
    How to open lg dle2514 front load to clean blower and vent
    Remove the 3 screws holding the top of the dryer.  Push the top towards the rear and remove top.
    Remove the front control display board by removing the 2 screws and unsnapping the control panel.
    Remove the 4 top screws hold the front panel and the 2 bottom screws in the door frame area.  Remove the light switch wire connector.  Tilt the front panel forward and lift up.
    Apr 29, 2008 | LG DLE2514 Electric Dryer
    Dryers Logo
    188 people viewed this question
    Top Dryers Experts
