Question about Fisher Paykel EcoSmart GWL15
Problem with Fisher and Paykel EcoSmart GWL15 door won't lock
The power comes on and the door will not lock. I just keep getting a beeping sound
    Top Expert:
  • Fisher Master
  • 9,472 Answers
You will need to replace the lock assembly.
Posted on Dec 03, 2012
SOURCE: Fisher and Paykel EcoSmart GWL15
tilt the machine to get to the bottom and there is an electric pump that you can remove with no tools, you twist if out. after that is removed you should see what has clogged your pump.. I spent 4 hours disassembling my entire machine , cleaning it, trying to find out what was wrong. And the fix could of just taken me 1 minute.. Next time... But at least I know how to take everything apart now, very easy and simple machine to work on.
Posted on Apr 21, 2009
  • 51 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 Machine won't
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
  • 1606 Answers
SOURCE: my fisher and paykel ecosmart gwl15 won't do a hot
There are several possible causes. To track down the problem, first shut off the water supply valve feeding the washing machine, then remove the hot water hose from the machine and direct it into a bucket. Turn on the water supply valve. Does water come out? Is it hot? If you only get cold water, then you need to insulate the pipe between the water heater and the supply valve so you get hot water faster (assuming the water heater is working!)
If you have a supply of hot water, then check the inlet screen where the hose connects to the washing machine. Perhaps it is clogged with lime or sediment. If it is clear, then you have a fault in the hot water solenoid valve or water temperature selector switch.
Posted on Dec 05, 2010
  • 6277 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 no power
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens ( or if there was nothing wrong with the breakers/fuses in the first place) sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 22, 2011
  • 6277 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 NO POWER Doesnt
Whoops- answered you other posting first, sorry ;-0)
The same thing applies- I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
John C
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
After washing my fisher paykel toploading washer will not empty out
possible a blocked pump , it shud beep , come up with a code read the 8 lights on the top
Jan 25, 2010 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel EcoSmart GWL15 Machine won't agitate or spin - two yellow lights come on, and machine beeps every second or so. This happens even with the power off.
Jun 12, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and paykel washing machine
If you can indicate which lights are displayed when the machine is beeping,that gives one the fault code to be able to tell what the fault is!!
Jun 28, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
73 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
