Question about Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H
Kohler Whirlpool tub motor wont turn on
During the recent ice storm we had various electrical issues such as all our controls on our furnace were blown, phones had to be replaced, toaster oven died, fish tank controls all died. We believe we had power surges. I just recently found that my whirlpool tub (less than 1 yr old) won't start. Do you have any quick check homeowner ideas before having the whole thing dismantaled and replaced. I was reading about some reset switch in the instruction manual, but don't see any button on the pump so I'm thinking that may be beyond me. I'm really hoping I don't have to replace the whole pump given the cost in the first place.
  • LATRKA Feb 05, 2009
    I don't know if it helps but, we had power surges and it took out alot of things in my home. My whirlpool motor in my tub quit working and I took a panel off, looked for a reset switch, could not find one. So I checked the power going to the motor with a lamp, and it didn't work. I don't know why, but I tried another switch in my bathroom and the lamp didn't work so I reset the GFCI on that plug and the lamp came on. I ran back to the tub, with my lamp, plugged it into the plug and it worked. I have 2 other plugs in my bathroom that have been working fine, I had no idea that the tub and the unused plug by the bath door were on the same circuit.
    So reset all your GFCI's in the bath, make sure they are all working and plug that motor up.
    I sure hope that was the only problem so you can get your money back.
We had the same thing happen to our Aker brand whirlpool tub.  The fix was a replacement timer/control piece which is connected by two wires to the pump behind the tub (access wall) and plugged into the outlet; however, this cost $150 for the part and $85 for the service call (all he did was take the part out and ship me the replacement part which was easy to do).  Problem I have now is that the motor won't shut off unless I unplug it.  I am waiting for a call back from the repairman who sent me the part.
Posted on Jan 14, 2009
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Whirlpool does not turn on. Kohler Model K-1474-V
The chances that is problem you are experiencing is related to the suction cover is extremely remote. The suction assembly doesn't have anything to do with the tub motor operating.
The issue is most likely with the motor not working or the air switch in the motor malfunctioning.
What does the control look like that you use to turn the pump on/off?
Is it an air button or an electronic switch?
Jan 29, 2013 | Kohler Home
We have a Kohler Purist Air Bubble Massage tub... the last couple days the dial has randomly started lighting up with the green light tracking down the middle and you can hear the motor or the jets on the...
This is sounding like a relay not working on the circuit board inside the control box. You will want to have a Kohler service center send someone out to have it checked. You most likely need a new control box.
Aug 14, 2011 | Kohler K-1110-AH-0 Purist whirlpool with...
Kohler Whirlpool tub motor problem. Turn motor on and trips GFI. It looks like the GFI is wired right and suggestions
Unplug tub from GFI, does GFI hold, plug something else into GFI to see if it holds under load. If all is ok then make sure you have a good ground from the motor to the GFI and the polarity is good. If 120 vac black wire to gold post, white wire to silver post and ground to green. Check proper connections, including polarity and ground at tub junction box and at pump motor it self.
Mar 21, 2010 | Kohler Home
Motor not working at all. Won't even go on
a good electrican will check for power but may not be able to test a printed control board. Maybe simpler to get a spa repairman
Aug 12, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks. this unit has been recently installed within the last week
You say that it doesn't leak during showers. The next step is to plug the drain 100% so no water will drain thru the drain assembly. Fill the unit up to just below the overflow drain and leave overnight to see if it could be leaking from the outside of the drain plug assembly or leaking from the jets/drain from the whirlpool feature. If was just recently installed was it professionally installed. Should be covered by warranty.Try this then if its not determined what the cause we will go to the next level of investigating what it could be.in it peak all around to see where the water is comming from. Use a flashlite so your not kneeling in mosture with a electrical light in your hand!!! Good Luck!
Jul 04, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
My kohler whirlpool wont stay on. It turns off about 1 second after i turn it on
You have a bad capacitor its located on the top of the electric pump motor. Be sure to turn off the power before attempting to replace it.
Mar 04, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Unusable new oven after ice storm
HI. the storm has caused an electrical surge that traveled through the home wiring system and, the Oven control received the hit in this case. it is damaged at this point, and it should be replaced asap, if possible. this code represents a major control breakdown. the board is ruined.
replace it asap.
Dec 17, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H Logo
3,736 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
