Question about Dryers
Clothes dryer ends sensor cycle clothes still wet
SET ON SENOR DRY AND WHEN DONE CLOTHES STILL WET.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
catriver
  • 878 Answers
SOURCE: Clothes do not get dry when using the sensor dry setting on GE dryer.
Ok, Jeff, I see you have a front loader, electric. On this model we have inlet thermistors, outlet thermistors, and the sensor bars are non serviceable, which means they are part of the blower housing. Not a big deal. Let's put it into a test mode and test the voltage drop of the sensors. They are on the inside of the drum just below the vent gate. 2 bars. Unplug the dryer for 30 seconds. Plug it back in and within 10 seconds press in this order: signal button, delay start, signal button again and delay start again. The consol should show t01. This is test 1. You want to turn the main dial clockwise until the test shows t09, this will be the sensor test. With the drum dry it should show around 5 volts DC. Now take a wet rag and place it over the bars, the display should show a voltage drop to around .5 or 1volt DC. If it does this the sensor is working properly. See if you can run this test successfully and post back. Catriver.
Posted on Jan 28, 2008
  • 66 Answers
SOURCE: UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Posted on Nov 13, 2008
SOURCE: Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Posted on Feb 09, 2009
  • 3 Answers
SOURCE: LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Posted on Mar 27, 2009
milten1
  • 1304 Answers
SOURCE: Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Posted on Oct 06, 2009
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
I have a Bravos clothes dryer and when the cycle is finished, it is very damp, wet and the clothes are not dry. What can I do?
This dryer automatically starts in the "sensor dry" mode. DO NOT use the "sensor dry" mode - use the timed cycle where you manually set the time. The sensor is in the back of the drum, and it frequently misreads the wetness of the clothes, especially if there is a t-shirt or something light in the back and towels or something heavy in the front (near the door). If you are still under warranty, you can have the sensor replaced (or purchase one), but it only helps slightly.
Oct 18, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The Dryer heats up for a while and the stops heating after running for a while.
Without the specific model number to work with, I'm taking a guess that your dryer has a sensor at the back of the drum. That is the dryness sensor that the clothes rub against and let's the dryer determine if the clothes are dry, according to the setting you selected on the control knob.
First thing to do is use some Windex on a clean cloth to clean the senor strips as use of dryer softener sheets can leave a residue that builds up on the sensor and could be causing it to stop.
The other thing you can do is use the timed dry cycle to see if the dryer works correctly. If the dryer works OK in the regular timed cycle, then it is possible you have a defective sensor.
Without more information about your dryer, It is difficult to provide more possible diagnostic steps and provide you with a possible solution.
Jul 28, 2009 | Whirlpool Dryers
Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
Feb 11, 2009 | Whirlpool LEQ8611L Electric Dryer
Nov 10, 2008 | Dryers
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
