Question about Hardware & Accessories
HOW TO USE THE TUNGSTEN E-023 timer clock - Hardware & Accessories
  • 5,245 Answers
1) Tungsten is not a brand, and probably means tungsten light bulbs or filament-type incandescent light bulb.
2) Copy following link:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) Add comment and include photo of timer or describe timer in detail
Posted on Dec 04, 2012
Having problems programming thermostat. It is a digital 7 day timer
Programmable thermostats and timers require program to be entered using keypad
Program 1, with ON or OFF displaying somewhere on screen
Program 2
Program 3
Each program needs ON time, and OFF time, and day(s)-of-operation selection.
Copy following link for possible manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#TM-023
Oct 28, 2012 | Hardware & Accessories
We have Noma thermostat and are having problems programming it
Usually it means:
Program 2
Program 3
I bought timer model #402A. It says 1250 watts tungsten rated. Here is my question: I have a demhumifier that draws 1800 watts-can I use the timer and what does 1250watts tungsten mean? Thank you.
1250 watt tungsten: Tungsten is the tungsten filament in light bulb.
So 402A timer is rated for light bulb only and not dehumidifier motor load.
1800 watt dehumidifier will burn 402A timer, and could start a fire.
I suggest Intermatic heavy-duty appliance timer HB113C:
http://waterheatertimer.org/pdf/070-appliance-timers.pdf
http://www.smarthome.com/25071/Intermatic-HB113C-120V-20A-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Jun 24, 2011 | Tork 402A 24 Hr Mechanical PlugIn Timer ...
I installed a digital timer GE 15086. Does it work with fluorescent lights?
15086 manual says 15A Tungsten.
Tungsten is incandescent.
manuals usually say CFL or fluorescent if they are made for those loads.
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Honeywell (500 watt/40 watt minimum) Aube T-1032 handles fluorescent and halogen
http://waterheatertimer.org/Aube-timers.html
Woods 59028 works with CFL
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | General Electric Hardware & Accessories
Replacing timer motor
T-104 has 240Volt clock motor
WH-40 water heater timer has same 240Volt clock motor
T-103 has 120Volt clock motor
T-101 has 120Volt clock motor
T-100 series 120Volt and 240Volt clock motors sell at Grainger for $16
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See large image of clock motor on back of Intermatic timer
http://waterheatertimer.org/images/Back-of-T-104-800.jpg
To replace clock motor you need 6-sided star-screwdriver from auto parts store or hardware
You may also need tweezers or magnetic screwdriver if tiny screws fall down behind timer when replacing
Steps:
Order 120 or 240 volt clock motor
Turn off power to timer
Remove plastic cover over screw terminals
Take photo of wiring or make a drawing
Note exactly which terminals the clock wires connect to
Clock motor wires can connect to either terminal, there is not a plus or minus wire to clock
Loosen screws on front of timer to remove white-colored clock motor wires
Push the spring retainer located inside box at top ... this will release timer mechanism from box
Tip timer out and then lift up to release timer
Replace clock motor that is held by 2 screws
Keep clock wires away from other timer parts on back of timer
Snap timer back into box
Re-attach wires to terminals just like they were before
Tighten screws very tight against copper wires
Turn on power
Check that dial is rotating as time passes
See more
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Oct 17, 2010 | Intermatic T-104R3 220v timer in a rain...
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
Oct 01, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
Is the intermatic standard lamp and appliance timer..TN111C...powerful enough to start up reliably a 400 -430 watt metal halide or high pressure sodium light?? Thanks
intermatic makes a timer for window air conditioners its the same design and only a few bucks more is more robust . I just tested my 175 mh lamp and it draws 1.9 amps on start up the amps go down after it starts.. harbor freight has a cool timer also (cheap) But please try to buy the timer made in the good old USA ....Jay
Aug 20, 2010 | Intermatic TN111C Standard Lamp &...
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Tungsten E2 - clock drifts
Nothing they did and nothing you did will fix it. They timer inside is imperfect and will never stabilize. Mine didn't either. Used my phone for my watch
Nov 18, 2007 | Palm Tungsten E2 Handheld
Hardware & Accessories Logo
61 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
