Suddenly the internal Hitachi dvd drive, model no HL-DT-ST RD-RS BH30N, has stopped working. I get this under Device Status: "Windows cannot start this hardware device because its configuration inform
Using a DELL Vostro 430, Windows 7 Operating System
    Novelist:
  • 250 Answers
If you are a non-technical user then don't edit registry keys manually the best solution is to use the best registry cleaner that will also fix other registry errors. Use Intel Software Partner Reginout.
Posted on Dec 05, 2012
4 Suggested Answers
hardkiss69
  • 43 Answers
SOURCE: UNABLE TO DETECT CD/DVD ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Your registry might be corrupted (code 19)."
You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 28, 2008
cabanagj43
  • 225 Answers
SOURCE: hl-dt-st dvd+-rw gt10n not working Windows cannot
check the fix here or you can follow the manual steps for xp and vista
http://support.microsoft.com/kb/314060
Posted on Oct 12, 2009
  • 179 Answers
SOURCE: Windows cannot start this hardware device because
Try uninstalling it then reboot your computer and let the computer find and re-install it for you. This will "Hopefully" correct the registry error.
To un-install your DVDram.
Click Start button on bottom left of your screen.
Right Click on "Computer" Or "My Computer" (depending on which Windows version you are using) in the box that pops up.
Click on "Manage"
In the box that pops up look in the left hand frame and click on "Device Manager"
Click on the "+" sign or Arrow (Windows version difference again) on the DVD/CD Drives option.
Right Click on the drive causing the trouble. (There may be a yellow exclamation mark beside it)Then click on "Un-Install" Click Yes if a box pops up asking if you are sure then when it tells you. "Reboot" your PC.
If your drive is NOT in your DVD/CD drive options it may be further down with an Exclamation Mark beside it. Just use above instructions for that instead.
Hope this helps and gets you up and running again. :)
Posted on Jul 17, 2010
My Cd-Rom doesnt work for my Acer Notebook 2930
Got to the Acer Web site and look under drivers and downloads. Select your model # and download the corresponding drive. Your prblem should be fix
May 15, 2009 | Acer Aspire 5100 Notebook
Tip
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP Home)
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP) [IDE]
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39. Or the drive simply does not appear in My Computer or Device Manager.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
on Sep 12, 2010 | Computers & Internet
Cd\dvd is corrupted or missing (driver detectiv)
Download microsoft fixit from http://www.ziddu.com/download/6528022/MicrosoftFixit50027.msi.html and install it in your pc ,once its finished jst restart your pc and see it will work
Jan 19, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
DVD Drive not reconized,"HL-DT-ST DVDRAM GSA-T50N"
Dear Sir,
It is not problem with your hardware,it is problem with your operating system. This happens due to invalid registry entry on the system files,you may clean the registry by using glary utiliy or any other free registry cleaning software,it may solve your problem.If it is not you have to reinstall windows operating system by formatting your system drive.
if you find any difficulty post a feedback,we will glad to assist you.
I think it helps
Have a nice day !
good luck
Sep 14, 2009 | HP Compaq Presario SR1420nx...
GMA 4082n device driver not working properly code 39
check whether the device is detecting properly on bios or not
Oct 01, 2008 | Computers & Internet
Go back to the device in device manager, right click on it and select properties, then under the driver tab click on "Roll back driver" button and see if that does the trick.
May 07, 2008 | Toshiba Satellite P100 Notebook
HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
HL-DT-ST-DVD-RWGRA-4120B cannot burn
Drive might be dead. Try another drive to eliminate the drive as being the problem. Also try DeepBurn writer software.
Nov 22, 2006 | Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner...
Computers & Internet Logo
David Payne
David Payne
