Question about Kichler TRANSFORMERS - PROFESSIONAL SERIES - 15PR200-SS - Stainless Steel
Model 30900 Keeps tripping at the switch in the box
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
My domena steam press keeps tripping switch
It has a serious fault, the trip tripping is saving you from a electric shock.
By the way if your ELCB is a oblong brown or black box with a yellow or orange test button its way outdated I recommend you get it changed for a modern RCD (much safer)
Oct 17, 2014 | Vacuums
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
My Mira Event Mk1 shower keeps tripping when i switch it on
It's wired with wrong cable if fitting a shower up tp 8.5 6 mm twin and earth needed if 9.5 or 10 fitted 10 mm twin and earth needed and fuse at mains box must be 45 amp
Sep 23, 2012 | Home
Microwave keeps tripping circuit breaker
Chances are you have a shorted "monitor" interlock switch, or its mount is broken.
See this door switch help file.
You can find links to helpful exploded view diagrams and part ordering help here.
To give you more specific help, we would need the brand name and
full model number of your microwave.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Aug 30, 2012 | Microwave Ovens
I have an LG Air Conditioner (model LST243H-2). The circuit switch (in the fuse box unit) keeps switching over to off. My apologies that I'm not technical in my explanation!
Please do not activate again.Call repairman. The circuit switch trips due to:
1. Compressor hing amps. 2.Any short circuit.3.Compressor grounded.
By resetting the breaker without rectifying the fault will make major expenditure and also (sometime) major hazards. Hope, you keep my advise.
Jan 05, 2011 | Heating & Cooling
Repair cpde 30900
it means you need to reset the computer, do this by removing the positive battery cable for 10 mins.....
Oct 23, 2008 | 2007 Mercedes-Benz ML320 CDI
Trip switch
is the dishwasher on its own circut breaker if so whats the size
Mar 17, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Kichler TRANSFORMERS - PROFESSIONAL SERIES - 15PR200-SS - Stainless Steel Logo
47 people viewed this question
Top Kichler Hardware & Accessories Experts
Scott Jelt
Scott Jelt
Gene Haynes
Tom Chichester
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
