Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Went of vacation upon returning Rheem water heater not working unable to ignite burners
  • Rheem Master
  • 5,245 Answers
1) Copy following link to troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake located under combustion parts, and check if TRD glass vial is broken due to overheating caused by reduce air intake and slowed exit of combustion by-product up the vent.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
3) Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Dec 03, 2012
  • 35 Answers
SOURCE: Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Posted on Jan 09, 2009
  • 234 Answers
SOURCE: Rheem Powervent2 water heater stopped working
I would try reset the the power to the unit to see if it will work.If not then I would for a high limit out on reset.
Posted on May 02, 2009
gary1121
  • 332 Answers
SOURCE: the water heater will cycle 5-6-7 times with no
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
Posted on Jun 06, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • 145 Answers
SOURCE: Rheem PowerVent Mod# 21VP40E-1 A S/N 0197106452
CHECK THE POWER VENT UNIT
Posted on Jan 08, 2010
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
I have a 50 gallon power vent lp water heater. the water was under water this weekend. when i try to ignite the heater i can not see the spark at t he burner. When I remove the blue ignition wire from the...
Your power vent water heater with electronic gas control went under water.
http://waterheatertimer.org/Flooded-water-heater.html
I suspect the gas control valve is bad, and possibly the ECO and FVIR sensors shorted.
Repairs might require replacing gas control, eco, fvir, igniter, and then clean burner and combustion parts.
Open following link to identify typical gas valves: and possibly read service manual for troubleshooting that model.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Might be easier to replace water heater
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Rheem 50 GAL FVR Propane Gas Water Heater...
Code 11
Before calling service technician, open following links for Rheem troubleshooting resources including error codes.
Error codes are considered start-point for troubleshooting.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error 11 is no ignition.
This problem can probably be solved by routine yearly maintenance shown in instruction manual which recommends: Yearly cleaning, adjustment and inspection of burner and combustion parts.
The yearly maintenance would check incoming gas supply, venting, wiring and grounding, and burner and ignition parts.
All gas water heaters today require same maintenance: tankless require yearly, and tank-type require periodic (1-3 years)
Jul 03, 2011 | Rheem Tankless Hot Water Heater...
I have a model 6G40PVW-40F water heater and we have no hot water... the thermostat light on warm/vacation is on and so are 2 other lights...If I diconnect it and re-connect it then it will start..the gas...
Most gas water heater problems today can be solved with yearly maintenance that includes cleaning burner parts, clean air intake, check venting, check electrical connections, bleed gas line, and check gas pressure.
Gas water heater manuals recommend yearly maintenance by service technician.
In past years, gas water heaters required less maintenance, but they were less energy efficient and more dangerous to operate.
Sounds like you have Intellivent gas control valve thermostat.
Open following link to identify gas valve and see error codes:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Error light on vacation + 2 other lights = 3 possible conditions:
1) Wiring error: check outlet with circuit analyzer:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
2) Pressure switch tubing not connected, air intake obstructed (clean intake), or vent exhaust obstructed (check for proper venting).
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
3) System in lockout: Low gas pressure, hot surface igniter not positioned correctly.
You can do some of this yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
MODEL NO. RTGL 74XN\r\nNOT WORKING SAYING CODE [C211]
Before calling service technician, open following links for Rheem troubleshooting resources:
C2 11 is no ignition:
Tankless water heater should have yearly maintenance that includes cleaning burner parts, with check of ignition parts, wiring, ignition sequence, gas supply, and bleed gas line if needed.
Chances are that your unit needs to catch up on maintenance.
Maintenance can also catch any condensation problems and make venting adjustments so parts are not degraded due to vent issues.
Tankless should also be delimed each year to preserve efficiency of heat exchanger.
Jun 29, 2011 | Rheem Tankless Water Heater RTG-74XN-1,...
PTG-74PVP-2; Where can I see/get/download a parts diagram? I continue to have O-ring failure on what appears to be the Water Flow Solenoid. The unit is installed at my vacation home, I shut down and...
Open following link for troubleshooting resources including Rheem contact information.
High water pressure might be causing problem.
Use Brady BTG-100 pressure gauge to check pressure on nearby spigot.
Add a pressure reducing valve on incoming water line.
http://waterheatertimer.org/images/Check-water-pressure-250.jpg
Water heaters, tankless and tank-type are damaged by high water pressure 80 psi.
House plumbing fixtures also have shortened lifespan.
However if water pressure or water flow are too low, then burner will not activate.
Tankless are like bowling on a ship sometimes.
Repair most tankless water heater problems yourself, same day, any brand, for $320
May 02, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
Error code C2 11 is 'no ignition'
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
Apr 18, 2011 | Rheem Tankless Hot Water Heater...
I have a rheem water heater and it has went into vacation mode and i have no hot water. how do i get it out of vacation mode
Do you have the model number? There is usually a temperature control knob on the heater that you turn to VAC, that just keeps it lit. Usually, setting it to 120°F is adequate.
Apr 06, 2010 | Water Heaters
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
145 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
