Question about Frigidaire GLTF2940ES Front Load Washer
To what does magnet on dispencer door connects to
The part is not available thru any of the authorized suppliers and would take 3 weeks minimum to arrive if ordered. I took a HARD magnet off the fridge door (the ones that hold notes and pictures up) and glued it to where the Reader Sensor would be just behind the frame where the Dispenser Drawer closes. Presto, the washing machine worked and did not display the DDO error message.
Posted on Dec 05, 2012
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Tip
Ddo mean
soap dispencer open... or on side of soap dispencer have small magnet not on positionor misplace
on Aug 05, 2010 | Washing Machines
The dispenser door is stuck in the closed position. No matter how much I try to jiggle it open the door will not slide out. How do I get the door to open without breaking something?
Hi stuwstark, you could try running a quick wash cyle without any clothes in the tub once cycle is activated you will hear water flowing through the dispencer holder from there you can try riggling the dispencer to see if it will loosen up, in some cases the dispencer holder can become stuck due to dry soap powder clogging up the sliding rails also the dispencer holder can become stuck due to the liquid detergent box "insert" becoming loose and jamming it self up against the top casing of the dispencer holder so by applying the cycle when the water flushes thru the holder could ease the hard powder or could float the insert making it easier to open,try it and see how you go, thumbs up if it helps thanks.
May 06, 2011 | LG WM-2277HW Front Load Washer
Maytag skybox 1976AAB wont dispence
I had the same problem. The hinge pin on the dispensing door was rusted and this kept the door from closing completly. The door sensor magnet was not making contact with the door sensor and this caused the error. I removed the pin, sanded it down and it before reinstalling. It works fine now.
Apr 05, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
The dispencers in the door doesnt work where is
behind the dispenser control panel. Could be the solenoid valve or the water valve, too.
Mar 08, 2009 | Frigidaire FRS3R5EMB Side by Side...
Magnet came out and now washer won't run
on the under side of the dispencer, remove it, flip it over, fit it in with some glue, as far toward the inner part as possible, put it back, try the washer, if it still doesnt fill, try pulling it out a little and see if that works, if it does this is the amount you need to move the magnet back.
Feb 10, 2009 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Front Loader Washer will not turn on at all???
it came from your dispencer ..it activates a sensor on the unit right side,,,,take your dispencer out turn it over and that magnet goes on the left side when dispencer is right side up....yes that magnet is neeeded to start unit...onthejob
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Water filling issue with mty kenmore 417.44052400
Yes on the dispenser door there is a magnetic switch that looks like a thin black cylinder similar to a short pen . About 1 1/12 long. It may have been dislodged. Make sure the dispenser door is closing all the way.
Aug 17, 2008 | Kenmore 44042 Front Load Washer
Washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Aug 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
