Question about GE Refrigerators
Replaced ic maker and it leak under refrig - GE Refrigerators
    Top Expert:
  • GE Master
  • 9,472 Answers
Check the water inlet valve.
Posted on Dec 03, 2012
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: My refrigerator is leaking water
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 26, 2011
Refrigerator leaking
this means that when the refrig goes into defrost depending on the age either the hole for the water to drain out after defrosting cycle is plugged and needs to be thawed out and blown out with compressed air of if the water drains out under the crisper droor or behind the crispers the drain is plugged there. it could also be a drain heater problem. dont know age of refrig.
May 26, 2012 | Hotpoint Refrigerators
Water leaking under fridge
HI,,, 1-check evap drain ice up or pluged in the bottom of the freezer compartment,2-check for leak if your refrige has ice maker for tube damaged or leaking in the back of your box,3-check water tray pan for damage ..good luck..
Jul 04, 2011 | Whirlpool Refrigerators
Leaking water maytag plus rsw2400eam ...ice maker not hooked up. seems to be coming from freezer side can you help
When your refrig goes into auto defrost the water normally goes down a drain tube and into a drip pan under the refrig, then it evaporates. But now your drain in plugged somewhere and you will need to find it and clean it out. Hope this gets you going in the right direction.
Jun 05, 2011 | Refrigerators
The ice maker in my Whirlpool Gold refrigerator has stopped making ice. There is ice in the tray, but it won't empty itself.
If the " tray " you are refering to , is the ice maker mold , then clean the coils in the front , under the refrig ( condensor coils ) . Also check the fan behind the refrig , to make sure it is working . An ice maker has to be 5 degrees to cycle . Bothe the coils and the fan , have to be checked to be sure the freezer is at the correct temp for the ice maker to opperate properly . If both are ok , then replace the ice maker .
Sep 23, 2010 | Whirlpool Refrigerators
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker hose running, not shutting off when ice tray is full causeing it to over flow. What can be done? Model CSX24D side by side
Replace the water valve ( pt # WR57X10051 ) . This piece is what the wall water line connects to on the refrig . Also , due to the age of the refrig , I would suggest removing the ice maker ( 2 screws ) and inspecting the inside of the mold for coating disintegration which would cause water to seep thru the uncoated aluminum ( or bubbled coating ) causing the ice maker to leak , but , appear to be overfilling . In this case , replace the ice maker instead .
Aug 05, 2010 | Hotpoint Refrigerators
No ice.
Pout about 2/3 cup of water into the ice maker . If it dumps but does not refill , replace the water inlet valve ( the piece the wall water line connects to behind the refrig ) . Also check the tube which fills the ice maker as it will freeze up , not letting water go into the ice maker . This is also caused by a bad water valve .
If the ice maker does not dump the water poured into it , replace the ice maker .
Also , check that the coils are clean under the front of the refrig , as this will cause slow ice production and can cause the ice maker not to dump due to too warm of temperature . Ice maker has to be 5 degrees to operate .
May 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Water leak where hose meets refrigerator connector
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Mar 01, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
