Neptune washer shows PF yet house power is fine and the dryer works.
    President:
  • 373 Answers
Try disconnecting the machine from the power supply, wait for 15 mins and then switch on again, the problem should then solve.
Else the problem might be with the power lines to machine or a damaged control board or a vent damage.please do post further comments if the problem persists.I would be glad to advice on this.all the best.
Posted on Jan 11, 2009
What causes maytag neptune dryer has pf error? My dryer worked in air fluff but not sensor or timer mode. Now it will not work at all. the lights on the control panel just blink . What could be the cause..
Pf shows a power failure hols the stop clear button and it should work again.As for your other problems I will more details such as a model number Gas or Electric dryer and example of the problem in detail
Aug 05, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune do code - makes buzing noise when start button pushed - then stops & do code shows - door will not open - also codes pf & po show up
My husband read the book - took the soap dispenser off & did something with a little cord - washer works fine now.
Dec 27, 2009 | Maytag Neptune Washer
Won't run, shows code PF
Well the code pf means power failure, check your cord and see if it connected ok. make sure you didn't blow a breaker in your powerbox.
Apr 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My neptune front loading washer is showing PF, but I did not lose power in the house , and now it will not restart and it was part way through its cycle.
Unplug the unit and let it set for a minute. Once plugged back in start the load from a new cycle, not in the middle of current cycle. If that dosen't work you have a short in the main power board.
Apr 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Neptune washer show PF and clicks off, door unlocks, and won't restart. House power is fine and the dryer works.
PF = Power Failure.
Unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
May 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Neptune dryer will not work
PF= Power failure hit the cancel button and it should clear then you will be able to select a cycle. Let me know
Jan 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
