Question about Sansui Televison & Video
Connection between sansui sled3900 and fios remote control
FIOS remote does not seem to be talking to tv. Cannot get volume, channel changing, on/off. Remote that comes with tv is fine.
SOURCE: X2Gen MV26T remote control code
i need these two if you know pls help
Posted on Mar 24, 2008
SOURCE: FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Posted on Jul 15, 2008
  • 247 Answers
SOURCE: remote control code
what is the exact brand and model of the remote?
Posted on Dec 20, 2008
SOURCE: Verizon fios remote cant be programmed to control insignia tv
Orion code 0490 solved it for me!
Posted on Jan 21, 2009
SOURCE: vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Posted on Feb 19, 2009
Magnavox 27tp82c101
Check it with an other code. Codes to check with Magavox with Verizon Fios are 1481,0081, 0057, 0733,0829, 1281 Select the code that give you maximumum functionality
Jun 05, 2013 | Televison & Video
TOSHIBA 36AF42
Your Fios box seems to be faulty
Mar 29, 2008 | Toshiba 36AF42 36" TV
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Is there any way to get my tv channel back on 4 with no remote?
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Apr 29, 2012 | Televison & Video
I do not have a remote for the tv but I am hooked up to fios cable system which has its own remote. All things seem to function but I can't change input. All I get when I hit the input button on fios...
The Fios remote work only on the Fios box only as u found that out.U want to control the tv itself,u must have the tv original remote as u used as for like the tv Input button and the tv and other functions of the tv itself.Try website like Remotes.com to buy the tv original remote.
May 09, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
FIOS remote
I am a FiOs Technician from Pennsylvania.. The most common occurence of this problem I encounter is when the TV is a dual-device.. Meaning that it is a TV with a DVD player or a VCR built into it.. Whenever this occurs, I do the 922 method using either the DVD or the AUX button on the remote instead of the TV button.
By the Way, if this works you must change the volume control to the other device using the 955 code in the Motorola manual afterwards in order to control the volume
I hope this helps
Jul 16, 2008 | Televison & Video
Remote optic
I HAVE NOT SOLVED THE PROBLEM YET. tHE TECH FROM YESTERDAY SAID TO REPLACE THE fios BOX. i RESPONDED BACK THAT iT WAS ALREADY REPLACED WITH THE SAME RESULTS. mY RESPONSE THIS MORNING IS DO i WANT TO PURCHASE THE PREMIUM PLAN??? I ALREADY DID AND HAVE THE RECIEPT TO PROVE IT??????? IS THIS FOR REAL. PLEASE - I JUST WANT TO GET MY REMOTE TO WORK AT ALL TIMES, NOT INTERMITTENT.
Tom Earles
609-731-1791
- press 922
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
