Question about Dryers
Hampton bay exterior wall mount light fixture blinks after installation
After i installed light fixture when it turned night the light bulb kept blinking. so i assumed it was bad so i bought another light fixture the model and that one started blinking also.
  • 843 Answers
If this is a unit that is supposed to turn on when it's dark, then the problem is that the sensor is "seeing" too much of it's own light. That is, when it get's dark it turns on, but the light it provides is telling the unit that it is sunrise and should be turned off. Find the sensor and cover it with tape, this will keep the light on. Now try to figure out where the brightness is that the sensor "sees". It may be a reflection from a nearby white surface. You might be able to redirect the lights (if they are reflector bulbs), or you might be able to paint the reflecting surface a brighter color, or you might be able to fashion a visor out of tape to shade the sensor from the reflected light. Good luck!
Posted on Dec 03, 2012
  • Al Kupchella
    Al Kupchella Dec 04, 2012
    Ooooops! Of course I meant paint the reflecting surface a DARKER color!
Crossedwires
  • 44 Answers
SOURCE: Hampton Bay ceiling fan with pull chains not working
Whether there is a reset switch on this unit or not would depend on the model. If you no longer have the owners manual you should be able to get it from the hampton web site. Many fans have a thermal fuse inline that probably was blown when the bulb broke. The cheaper models do not and then I would guess you burned out the switch.
Posted on Feb 09, 2008
  • 537 Answers
SOURCE: this Hampton Bay light fan fixture eats Light Bulbs
Read the manual to find out which size bulbs (base size and wattage) you need.
If you did use the right type of bulb and it lasted only 2 weeks, take them back to the store where you boght them for a refund.
Mike
Posted on Jan 17, 2008
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 351 Answers
SOURCE: I have the Hampton Bay 5-Light Track Lighting
Skill, patience, preseverance, and experience. You ned to cut and strip the wires so they "just fit" into the space provided leading to the connectyion screws. no room for stuffing , and no extra wiggle room for and bends or kinks .. You mightb try mounting the wires and then pushing the extra wire back up intio the ceiling junction box, thats what I do.
Posted on May 10, 2010
Can I replace the 13 watt CFL bulbs in my fan light fixture with a higher watt bulb
The bulb fixture itself should tell you what the max wattage is that you can put in there but they are normally at a 60watt limit.
Feb 25, 2015 | Hampton Bay Dryers
Hampton Bay Sidewinder ceiling fan. For ten years, wall mounted control functioned until it 'blew' when electrician was working on a remodel of another room. Installed another control (Progressive...
You called customer care about a Hampton Bay & they sent you Minka Aire??? Hampton Bay is a store brand for Home Depot. If The fan came with a remote, you probably need the one for your fan.
Aug 24, 2013 | Hampton Bay Sidewinder 04890 Ceiling Fan
I've had my Carriage House II ceiling fan for three weeks. Yesterday when we turned the light on it stayed on for a second or two and shuts off. It now does that every time we turn the light on. Even...
Check the bulb(s) to make sure they are screwed in securely. If it happens only when the fan is on, there may be a loose wire up in the housing, where the light fixture attaches to the fan. Perhaps, a wire nut is loose. If the light and the fan switches are wall mounted separately, the wall switch for the light may be bad.
Feb 05, 2011 | Hampton Bay Heating & Cooling
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Apr 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Feb 07, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
This Hampton Bay light fan fixture eats Light Bulbs
Mike
Jan 17, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Dryers Logo
159 people viewed this question
Top Dryers Experts
