Question about Mitsubishi WS-65711 65" Rear Projection Television
On my tv I have two ghost strips from top to bottom how can I remove them
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Presuming model listed here is correct first go to a unused video input to see if the strips are there or not----the answer to that will determine what steps to take.
Posted on Dec 03, 2012
Scrolling ghost bar on Samsung LCD TV
Majority of the time when you get a soft type of scrolling or distortion it is a poorly made cable or connector causing bad signal. I would replace that RCA cord altogether and go to the top end with and HDMI cable. If this is not an option buy a newer upgraded version of the RCA cable. The ones that come with everything are only really good for in a pinch
Jan 29, 2014 | Samsung Silver Tilt/Tilting Wall Mount...
I have Sony BX400 40” LCD Projection TV. It shows ghost image while reception through set top box, however, does not while on DVD mode. What could be the problem / solution. I have changed my set top box,...
hello there could be a few things that could be wrong 1 check the male aerial connection make sure it's fixed tight . 2 you may be getting interference from other devices near your tv like a cordless phone 3 your aerial could have moved slightly try retuning it again also make sure the aerial connect to the set top box and the lead from the set top box to the tv hope it helps
regrads
shaun
Dec 27, 2010 | Sony Televison & Video
My screen was damaged and I finally found a new screen for it. How do I get the molding off so I can replace the screen?
You need to remove the two strips one on top and one on bottom of the plastic frame on the front of your tv. They can be easily flip up with a small screw driver. After removing the strip, you will see screws that hold the frame to the TV set, remove all of them then take the metal strip off. remove the frame, the protective cover, then remove the screen. The mirror then need to be sit on the slot of the back cover then hold it with the 3 brackets on the top on the inside of the rear cover.
Sep 26, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Canon DR-9080c Ghosting Problem
Though I've never seen this on any scanner, I can imagine it being a reading glass out of place. This could cause a weaker reflected image overlaying the direct one. Look at the top & bottom glass strips in the transport area. They should look level & unbroken.
Apr 07, 2009 | Canon DR-9080C Path-Through Scanner
How to get to mirror and lenses on a pioneer SD-643HD5?
unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Oct 18, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
remove.
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
removed.
Jan 21, 2008 | Televison & Video
Problem with my tv
The ghost might be fix by replacing the stk chips. I posted the instruction in here http://www.fixya.com/support/t209258-panasonic_pt_47wx53_g
For Kevinsul, I believe this same chips over heat which degrade it's performance. When U said things, if you mean like spots then I don't believe it is this chip. But if you mean long strips ghost or lines then it's likely this chip problem.
Jan 01, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
Mitsubishi WS-65711 65" Rear Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
