Question about West Brass NEW Oil Rubbed Bronze Instant Hot Water Dispenser+Tank
No water at outlet
I am installing an instant water heater non pressure type, the problem is that water that water does not exit at outlet,could it be that water presure at inlet is too low or is the unit deffecftive?thank you
  • 700 Answers
Plidded up inlet is what it sound like, or too low like you said
Posted on Jan 11, 2009
T and p valve leaking and i replace it and pressure pushes out hot water
It sounds like it's doing it's job, by not letting your water heater turn into a missile, or exploding....The "T" in T&P stands for temperature. When it gets too high, the valve will open. The "P" in T&P stands for pressure. When IT gets too high, the valve will open. When they both get too high...you know the rest...The condition can be caused by many factors.
1. The house "pressure reducing valve" is letting in too much pressure. Any more than 80 lbs. is too much. 50 to 75 is good.
2. Hot water expansion in a closed loop system...no "prv" or "water meter" bypass...To fix, you can install a small "expansion tank" above the water heater. It will allow the extra bit of water to go somewhere temporarily, Letting the T&P valve stay closed. Installation is always on the hot outlet side, because high efficiency water heaters use a "check ball" in the factory installed cold water inlet nipple, which also doubles as a dip tube. (lets cold water into the heater at the bottom)
When a gas fired water heater turns on, there is a pretty fast spike in both temp. and press.
3. The gas control valve itself, has a non resetting 190 degree, "high limit" safety shut off feature. IF that were to fail, the control would run away temperature wise, but I have never heard of one failing.
regards!
Dec 06, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
I want to convert my rheem tankless eco150xlp3 to natural gas. There is a gas type chip that plugs into the main board as described in the install manual. Opened the burner and the orifice looks servo...
Sell it on ebay.
A simple chip change will not convert because the orifice for each gas is different, the gas control valve is different, NG and LP gas each burn at different temperatures and pressures... with propane having higher temps and pressures.
Don't buy tankless computers and expect trouble-free installation and water heating bliss afterwards.
Read the manual for maintenance requirements, and look at the parts sheet and ask yourself how such a complex machine will simply balance and monitor water flow, water pressure, incoming and outgoing water temperatures, gas pressures, vent pressures, gas quality, gas pressures, while connected to water, gas, venting and electric systems inside your home which each have innumerable problems on their own.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Install tank type heater for around $400 and live worry free.
Avoid Rheem products since they do not post service manuals.
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
Gene
h
Sep 25, 2013 | Rheem Tankless Hot Water Heater...
Insinkerator instant hot water faucet
Insinkerator stainless tank does not have anode rod to protect from rusting. So these water heaters rust out at welds. And must be replaced. And this is frequent problem.
Copy following link for installing under-counter water heater and see manuals for various models available. Non-insinkerator water heaters have anode rod to protect from rusting:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
Jul 23, 2013 | Water Heaters
Installed but not heating
State point-of-use electric water heater plugs in.
Check that outlet has power.
The water heater must be full of water or elements burn out instantly.
Test the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Match voltage to water heater:
This electric water heater, like all electric water heaters, will work on 120Volt, 208-240Volt or 3-phase unbalanced.
But wire size and breaker must match element wattage.
If you have outlet, check the wire size and breaker, and check what other devices are drawing power from same circuit, then add up total watts and compare with charts on link below.
http://waterheatertimer.org/Color-codewire.html#water-heater
Oct 20, 2012 | Water Heaters
How to adjust gas pressure
Question is unclear: type of water heater is not given.
Whirlpool sells tank-type heaters manufactured by other companies with outlet at local box stores like Lowes.
If you have tank-type NG gas water heater, then gas pressure is controlled by gas company. Call gas company to check pressure.
If you have LP heater, contact LP supplier.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Whirlpool Water Heaters
My waterheater has three water connections on the top of it one has a C for cold is that a inlet or outlet ? The other spot has a H for hot is that a inlet or outlet ? And the other one is not marked what...
My water heater has three water connections on the top of it one has a C for cold is that a inlet or outlet ? IT'S THE COLD INLET. The other spot has a H for hot is that a inlet or outlet ? IT'S THE HOT OUTLET. And the other one is not marked what is that one for and is it a inlet or outlet ? please email me at nsjuby@yahoo.com. The last one is a pressure release valve that lets off excessive pressure when the temperature goes too high in the unit. When you install the heater, it should be installed into the drain pan that existed before or into a new one. You should also install a drain pipe from the valve to that drain pan, or into the drainage system for the house. This may depend on the codes where you live. Also install a good quality shut off valve on the inlet side for emergencies. A Ball type is good. Hope this helps,
Best Mark
I'm new to this site, so I'm not sure if I can email you directly or not. I believe not. Good Luck.
Dec 28, 2010 | Whirlpool Water Heaters
Carver cascade 2 No water at all comes out of the hot water outlet. The inlet non return valve has been changed & is working correctly.
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Oct 06, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
The water from the instant heater smells bad. I've changed the filter but the odor remains. What is this?
if the water supply from other outlets of the house are fine, the unit itself developed some mold or other contamination from period of non use. it will need to be flushed
Sep 08, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Size and installation for instant water heater
Ariston gl4.0 should be fine if used inline with your hot water heater. Used alone it will likely run out when dishwasher is filling and you are using sink.To use your existing hot water for backup: 1 connect existing HOT water line to cold (inlet) on ariston, 2 Then HOT (outlet) from ariston to sink and dw. If you want instant hot water at a sink 10 feet away: use 3/8 pex pipe from ariston to sink, so you only have to run off a cupful or 2 before hot water arrives at sink.
Aug 30, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
West Brass NEW Oil Rubbed Bronze Instant Hot Water Dispenser+Tank Logo
87 people viewed this question
Top West Brass Water Heaters Experts
Paul Carew
Gil Shultz
Are you a West Brass Water Heater Expert? Answer questions, earn points and help others
