Question about 1aauto.com
My 2000 alero wont start and the codes on the OBD reader are p1137, and 0137
    Sergeant:
  • 298 Answers
P1137 Lack Of HO2S Switch - Sensor Indicates Lean
Read more: http://engine-codes.com/search_codes.php?var=P1137#ixzz2LBsTKxjw
Posted on Feb 17, 2013
Why wont my OBDII monitors reset on my Ford Expedition?
Does it have remote start? If yes then your could be done.
To keep the remote start codes in the truck requires a 9v battery to save the codes in ROM, ROM has to be flushed to get rid of the OBD codes. If you do not have remote - pull +cable off battery for 30 seconds. If you have other settings -- personal radio stations ...... you could loos these as well.
OR purchase and OBDII handheld reader -- with code clearing capability.
Oct 14, 2014 | 2000 Ford Expedition
1999 oldsmobile alero, no dash gauge response, no obd2 plug voltage
Check pin number 16 of the OBD 2 diagnostic connector, it should have 12 volts, if not the port will not power up the code reader or scanner. See diagram below.
Oct 31, 2012 | 1999 Oldsmobile Alero
2000 jeep cherokee starts slow. doesnt idle well, and radio clock resets...i installed a new battery, new starter and checked all ground on engine. what is it??
It sounds pretty obvious that it is losing battery power. That is about the only thing that will cause your clock to reset itself. I would be taking a HARD look at the battery cables and connections. By this I mean to do some actual circuit testing like performing voltage drop tests.
Also, since your vehicle is an OBD compatible vehicle (which means it is capable of self-diagnosis), it would also be a really good idea to perform a FULL computer network scan to see if there are any clues there.
By "FULL" I mean scan ALL the modules and check the data - NOT just hook up a generic code reader and try to pull codes. If the PCM is losing power you will not get any generic OBD fault codes from a code reader. However one of the other modules will most likely report communications faults with the PCM. Cheap generic OBD code readers cannot perform these functions.
Apr 09, 2012 | 2000 Jeep Grand Cherokee
Service engine light stays on and service vehicile
It is a "dummy light" and will come on to tell you that the computer has recognized a problem. You need to get a code reader or OBD-II computer and plug it in to read the codes. Then google the codes and see what the problem is.
Sep 30, 2011 | 2000 Oldsmobile Alero
Where is the OBD II code reader placed?
It would be under the drivers dash area, and it might have a black cap on it which will need to be pulled off. Hopes this helps
Aug 23, 2010 | 2000 Oldsmobile Alero
Where to plug in obd 2 code reader
under your dash on the drivers side. open the door, kneel down and look under the steering wheel.
Aug 05, 2009 | 2001 Oldsmobile Alero
Key wont turn
try to get a new keyreader i have the same problem im my 2000 olds im pretty sure thats the cars key microchip reader is bad
Jul 22, 2008 | 2000 Oldsmobile Alero
1aauto.com Logo
83 people viewed this question
Top 1aauto.com Computers & Internet Experts
David Payne
David Payne
Are you a 1aauto.com Computer and Internet Expert? Answer questions, earn points and help others
