How can I change from tv to freesat on my samsung smart tv
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Consult the owner manual but that should be in the setup or main menu you access with the remote.
Posted on Dec 03, 2012
I STILL CARNT LINK MY FACE BOOK WITH MY PANASOIC SMART VIERA IT SAYS INVALED TOKEN I HAVE RESTORED IT BACK TO SHIPPING SETTINGS ALSO I HAVE TURNED THE VIERA LINK ON AND STILL NOHING ANY MORE SUGGESTIONS
Resetting your TV should make your TV create a new Facebook token. This token should then be entered on your computer at www.facebook.com/device.
A tutorial on how to reset your TV can be found at http://shop.panasonic.com/docs/how-to/2013/tv/reset-procedure/How_to_Reset_your_Panasonic_Viera.html
A tutorial on how to register Facebook can be found at http://shop.panasonic.com/docs/how-to/2013/tv/register-facebook/2013_How_to_Register_Facebook.html
Aug 05, 2013 | Panasonic Smart VIERA TX-P42GT30B 42-inch...
Don't understand what you mean by changing from TV to freesat. Can you explain more? I.e. what equipment you have already to receive freesat and what source you're receiving your TV signal from at present.
Dec 02, 2012 | Televison & Video
Will my westinghouse tv work in the uk in conjuction with a bush hd freesat box?
Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Oct 27, 2011 | Westinghouse TX-47F430S 47 in. LCD TV
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
Freesat box connect to tv with hdmi cable when slect hdmi tv shows all colour screen no picture
i returned the freesat to the shop going to buy tv with freesat built in
Nov 08, 2008 | JVC Televison & Video
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Samsung TV T1-14P1
I think there must be a problem with the scart import on the television, thanks for your interest.
Aug 15, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
