The tv is not in the source list/edit name available
Hello my real problem is that in my menu neither the antenna nor the plug and play is available. My boyfriend did stuff he does not remember what he did, but afterwards I was not able to watch TV anymore which I did over antenna. He told me he did something in the source list, but does not remember what. so when I go to the Edit Name part I do not even see TV in there. Could you please help me to watch TV again. Thank you everybody.
  • 56 Answers
SOURCE: 42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Posted on Feb 19, 2008
  • 13433 Answers
SOURCE: just received my tascam DP02..manual
The song you have selected, the demo is protected, try anoter file.
Posted on Apr 15, 2008
SOURCE: Blackberry Messenger Symbols
Copy is Alt+trackball, paste is Shift+trackball. hth.
Posted on Sep 04, 2008
  • 65 Answers
SOURCE: Please help me get my user name changed to something simple..
you cant change your username... but you can change your password... better try for a new  gmail account with the username that you wanted
Posted on Sep 27, 2008
SOURCE: no channels on list
You have to search for the channels. Go to your setup menu, and go to setup, then select TV, then do auto channel search. It may or may not have to be set on tuner to get to the TV options.
Posted on Nov 03, 2008
I changed my tv from cable to an indoor antenna however I cannot get it back to set up to change it over to antenna or air. Help1
Do you mean the Curtis LED1930A 19" TV? If so, first check that the source is set to TV. Use the Source button on the TV (just below the power button) or the remote (to the right of the 0). You can use the up/down arrow keys to change lines in the Input list. Press Enter to confirm the choice if you are using the remote.
Next press Menu on the TV (the third button from the top) or remote (to the left of the 0). Use the left/right buttons to navigate to the Channel heading (the third item from the left). Use the Source key (on the TV) or press Enter on the remote to enter the menu. Use the up/down arrows to highlight Signal Type. Press Enter (or Source) and then use the left/right arrows to get Air. Press Enter to confirm the setting. Now you should be able to highlight Auto Channel Search and search for your OTA channels.
This is shown in the manual. The manual is available from Amazon here: .
I hope this helps.
(The Channel menu is not accessible when the input is not set to TV.)
Mar 29, 2017 | Televison & Video
TV has static but no picture. When I turn on the TV, I hear 2 clicks and static. Pushing the power button again, static stops and red LED light turns on. After 15 min. TV automatically shuts off.
Check your antenna is plugged in the right place.
Switch TV on then goto it's menu setting, if the menu appears then at least you know the screen works.
As a test, plug in a DVD player to one of the HDMI ports and try to play something. Make sure you select the proper input source from the source menu and see if you get a picture.
If you do then it narrows the problem down.
Next, from the menu, select TV source to see if picture comes.
There are a number of other sequences depending on what decoder or Viewer box you have, if it's just Freeview antenna then you may have a problem with that.
Make sure you've done the auto tune procedures too.....
Oct 11, 2016 | Televison & Video
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
Aug 24, 2016 | Olevia LT26HVX 26 in. LCD Television
Looking for manual for T24c55ond tv
Do you mean the Samsung T24C55OND? To change the TV source from cable to antenna, first make sure that your input is set to TV. (Press the Source button on the remote or the TV. The Source button becomes the Enter key when you use the Menu button on the TV.) Next press Menu and navigate to the Setup Menu with the Up/Down arrows. Press Enter to select the submenu. Navigate to the Plug&Play menu and press Enter. Move to the line for Auto-Tuning the TV Source and press Enter. Use the right and left arrows to select Air. Select Start and press Enter.
The user's manual for that is available on the product support page: . Scroll down or use the jump link to reach the Manuals and Downloads section. The User's Manual links are on the left side of the page. You will need to agree to the Samsung terms of use before the PDF will download. The above information is in the Getting Started section of the manual on page 16.
I hope this helps.
Jul 25, 2015 | Televison & Video
There is no Chanel coming to my tv. How can fix this problem with my remote
If you are not getting channels on your television, then your antenna is not connect correctly or the input method has not been set on the right one.
Connect your antenna source to the incoming area on the back of your tv. Check the name of the incoming source that you are using (antenna 1, cable, tv, aux, hdmi ect) and press the button on the remote to choose the right one. You will know you have chosen the right one when you see a tv picture. Go into the menu on your tv and choose to auto program the channels once you have chosen the right input method and it will locate the channels that are available in your area.
Sep 26, 2011 | Sony Televison & Video
We own a samsung flat screen HD tv, model: Ln46C530, software version: T-TDT5A6SC-10060. At the bottom of the screen there's line of windows that pop up, they say, series 5, wide color enhancer, hyper...
It sounds like you have the Store Demo Mode on. To turn this off, press the volume button. While the volume is displayed in the OSD (onscreen display), press and hold Menu for 5 seconds (or a bit longer).
Alternatively, you can find this in the menu. When TV is the source, press Menu > Setup > Plug & Play followed by Enter. (It's the second choice after Language.)
The manual is available here: . This is on page 7.
I hope this helps.
Jun 16, 2011 | Samsung LN46C530 TV
Purchased second hand 17/3/2011 (2007 model) plugged in power turned on power and plugged in antenna, box comes on screen saying"no sgnal" Antenna was already working another TV.
Based on the information you gave you will have to check/verify several things.
> You have connected an antenna.
> Go into the menu and set the signal input source to antenna/air or whatever its called. The previous owner may have used cable.
> Scan in the channels the antenna will receive.
> Save the list of channels.
You should now be able to watch stations via the antenna !!
Mar 25, 2011 | Televison & Video
I wondering only,how to connect my hard drive to the LCD TV
If you have an external usb hard drive and usb ports on your tv just plug it in. Sometimes the menu for usb drives pops up. If not, try to press source or input select, input on your tv remote. You must see your drive name in the list. Just select it and you should be able to access your hard drive.
Hope this helps!
Feb 13, 2011 | Computers & Internet
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
To change between cable and antenna on your TV,
Press Home to display the "XMB" menu.
pick "settings" on the menu
then pick "channel" on the next menu
under channel settings, select "on" for cable and "off" for antenna TV.
Your user manual is available for download and option printing at the following link :
May 16, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
