Question about Liebherr HC2062 Refrigerator
My fridge/freezer is making a cricket sound, what can I do!!
Service number 0920221-01
Fridge freezing food adjusting thermostat make no change
Sounds like the vent is stuck open on your model. Here is a service bulletin for your model=> HERE
APPLIANCE 911
Dec 14, 2015 | Indesit BIAA134 White 292 l Fridge Freezer...
KFIS29PBMS00 gets warm after a day of work
sounds like you need a repairman's services
Jun 24, 2015 | KitchenAid Refrigerators
Do I have a 20 pound cricket behind the refrigerator??
That's the compressor. Check the compressor mounts to see if they are cracked, loose, or have hardened or broken rubber bushings. Also check to see if the compressor housing is improperly touching something that transmits its vibration and acts like a sounding board. Sometimes there is a problem with freezer icing in high humidity conditions, leading to ice buildup on the refrigerant tubing at the compressor (excessive running) - this makes the tubing insulation rigid and things get really noisy. The fix is to shut everything down, let it defrost, and clean out the defroster drain tube.
If you can't find anything like that, you may have something going out in the compressor. If possible, make an audio recording and play it for a service technician at an appliance shop - he may be able to identify exactly what the problem is.
May 08, 2014 | Refrigerators
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
My smeg fridge is making a constant cricket sound noise constantly
first check for a cricket
if no cricket is found, it's likely one of your 2 fans. one will be down by the compressor and the other is inside the freezer compartment.
May 22, 2012 | Refrigerators
LG Fridge / Freezer GWL227YBQA
sounds to me that you have either a sensor problem or a main board issue. to avoid spend money and the intricasies of trouble shooting, call for service. Sears has a Service Smart Agreement that is reasonable and would cover needed repair up to 500.00
May 20, 2012 | Refrigerators
My fridge is making a loud nosies and it is not stopping
that is the auto defrost fan working,nothing to worry about.
Apr 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Liebherr HC2062 Refrigerator Logo
26 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
