Nikon F80 35mm Film Camera Logo
Posted on Jan 11, 2009
I have a MB16 battery replacement for my Nikon N-80
I need to remove the N80s Battery cover
so I can install the MB-16 AA battery
converter box. I will not have to use
the CR123a.
Thank You.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
2179
Points
5
Open the battery covr puh the spring in side and unlock the cover now u can install mb-16
Where is the battery door for pstsl21p52?
Replacing the Batteries
  • Open front cover and locate the battery compartment door.
  • Gently remove the two "AA" alkaline batteries located in the battery compartment.
  • Install two new "AA" alkaline batteries into battery compartment. Make sure to match the positive (+) ends of the batteries with the positive (+) terminals located in the battery compartment.
  • Close battery compartment. The low battery indicator should not appear in the display.
Feb 24, 2024 • Cameras
1helpful
Can I get user manual for Nikon MB-40 multi-power battery pack for F6 body?
I think the extent of the instructions is on the Nikon USA web site. Here it is
"The Nikon MB-40 Multi-Power Battery Pack accommodates eight AA (alkaline, lithium, or Ni-MH) batteries, or the Nikon EN-EL4 Rechargeable Li-ion Battery. The MS-40 Battery Holder comes with the MB-40. With the MB-40 attached, film can be advanced as fast as 8 fps.
When using the EN-EL4 battery, the Battery-Chamber Cover BL-3 must be used.
The MB-40 is also a vertical grip, and features a vertical grip shutter release, an AF start button, and Multi-selector and Command Dials for more comfortable and responsive shooting."
How do i replace the batteries in this device?
To install the batteries:1. With the back of the radio facing you, remove the belt clip (seediagram below) for easy access, then remove the Battery Coverby pressing down on the top center and sliding it down from theradio.2. Insert 4 AA batteries observing the polarity as shown. Installingthe batteries incorrectly will prevent the unit from operating ormay damage the unit.3. Return the Battery Cover by sliding it up on the radio. Replace thebelt clip, making sure it locks into place.
To install the batteries: 1. With the back of the radio facing you, remove the belt clip (see diagram below) for easy access, then remove the Battery Cover by pressing down on the top center and sliding it down from the radio. 2. Insert 4 AA batteries observing the polarity as shown. Installing the batteries incorrectly will prevent the unit from operating or may damage the unit. 3. Return the Battery Cover by sliding it up on the radio. Replace the belt clip, making sure it locks into place.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
1helpful
Battery exhausted, change them, take one photo, and camera says battery exhausted again. I have this camera one year and this is the first time this has happened.
Good quality rechargeable batteries are a must for these cameras. What I would suggest is AA' NI-MH rechargeable batteries the type that come already charged and when used and recharged will hold their charge up to 80% for a year. These batteries you will find will outlast any AA Alkaline type. If you are using a no name department store AA Alkaline type battery it's a wonder it even turned on.
What kind of AA batteries do i need to use for my Nikkon N80 with converter box. Can I use the regular alkaline batteries or do I have to use Iithium batteries.?
If you are referencing the added grip, MB-16, you may use rechargeable AA batteries, or other regular AA batteries. My preference is rechargeable.
3helpful
Disasembly of a phillips norelco shaver 7310xl in order to replace battery.
Remove the 2 screws on the back and remove the back cover. This will allow you to access the inner cover that has 3 screws. Remove those screws and take off the inner back cover to access the battery. Be sure to read the NOTE concerning installation on that page
You will find the battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
2helpful
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
My Nikon F80 won't turn on, I've tried changing the batteries in the battery pack and turning it on and off but I've had no luck.
Hi darciegracem, Does this happen with the MB-16 battery pack using AA batteries? If so clean the contacts on the battery pack and inside the camera. Make sure it is screwed snug to the camera. If it happen when using the two 123 batteries as well, it may need a trip to Nikon. These cameras go used for about $100 or less thus, you may not want it repaired but, rather purchase a used one from a reputable dealer. The F80/N80 is a very nice camera.
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
1helpful
Nikon MB16 fitting to Nikon F80
To quote Nikon. 'hold the camera's battery chamber cover at approximately 45 degrees to the camera body and then pull it out gently'.
Bill
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
