Question about Whirlpool Duet GHW9150P Front Load Washer
Loose drum drive pulley on whirlpool duet washer
Noisy, shaking will not shift into high spin cycle with full load. Ran diagnostics all ok. Cleared drain filter ok. Checked play on drum for bad drum bearing, seems tight to me without play. Pulled rear cover and belt dust everywhere. Pulley on forum had hots of play despite nut being tight. Removed nut and no sign of bearing problem. Shaft has two flat sides for pulley "key" but the pulley seems to rock and wobble. Looks like a replace of pulley and belt. Anything els E to consider?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You have the problem. Replace the pulley. Here is the part to order.
Posted on Dec 03, 2012
3 Suggested Answers
techbuster
  • 5081 Answers
SOURCE: whirlpool duet washer makes banging noise during
Sounds like the rear tub bearing has gone bad. Remove the rear panel and belt. Grab the drum drive pulley and check how it's moving up & down and side to side.
Posted on Sep 18, 2010
  • 6277 Answers
SOURCE: Whirlpool Duet Washer GHW9100LW1 symptoms of
Always worth while adjusting the 'balance'!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 01, 2011
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
SHAKING WASHER
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 25, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
237 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
