Question about Vehicle Parts & Accessories
How to deactive starter kill on my autopage alarm system
I couldn't open my gas tank door so I started checking all my fuses, I removed a couple relays and put them right back and all my fuses were ok but when I got into car to start it nothing happens, the dash lights come on but no turn over or sound or anything
reynosaelect
  • 165 Answers
SOURCE: Kill switch is on and I cant deactivate
you to disconect the main harness from the alarm.and take your car to a alarm repair shop.
Posted on Mar 17, 2009
  • 740 Answers
SOURCE: alarm wont shut off and lights keep flashing
This can be very simple look for alarm brain and unplug the brain, this vehicle should start. if it doesn't the look for valet switch it usually mounted under dash or on kick panel next to hood lever or close to where clutch pedal will be, Turn Ignition ON and in ON position flip switch the led light should stay on steady then the vehicle will start. If None of this works then you will have to take panel under steering column down and disconnect complete alarm system. Disconnect wires one ar a time and re-join them with the correct ones. It's NOT hard to do, there will be spliced into ignition wires.To do this you should disconnect positive lead on battery pole to stop the annoying noise until you are done. Good luck and contact if you need more help. Thanks for using FIX YA
Posted on Mar 24, 2009
SOURCE: I have a aftermarket alarm that trips 60 sec after armed.
if im not mistaken it does that because your interior lights dont turn off as soon as you close the door.. it delays a lil bit, and when you set your alarm it detects that the door is being opened. try arming your alarm after the lights have turned off and if that solved it you can take your vehicle to an alarm place for them to program your alarm to learn that function..
either that or maybe your door trigger wire is tapped to the wrong wire on the car...
Posted on Apr 06, 2009
emissionwiz
  • 80339 Answers
SOURCE: where is the relay system on a car alarm
it is a standard bosch style relay, it should be under the dash on left or right of the steering cloumn
Posted on Sep 11, 2009
logosc75
  • 625 Answers
SOURCE: i have the alarm system hooked up, i have the
The seven flashes of the parking lights when you attempt to remote start is the tach signal not being programmed. If you hooked up the tach wire already, turn the ignition on, press and release the programming switch three times. Turn the key off, press and hold the programming switch and start the car. Continue to hold the programming switch while the vehicle runs. The parking lights will be flashing while the tach is being programming. Hold for at least 15 seconds for a good signal. This allows the engine to "smooth out" into a normal idle rpm.
If the parking lights are not flashing, the tach is not being programmed. You may have skipped a step during the set up for the programming or, you have the wrong tach wire. If you went to a injector or coil wire, it is the uncommon wire. This means that there exists two or three wires at the injectors/coil packs. One or two of the wires are the same color at all of the injectors/coil packs and one wire is a different color at each injector/coil pack.
Posted on Mar 04, 2011
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
Autopage alarm wont let my vehicle start
Is this a new installation? Is this a remote starter?
If you have an alarm with a starter inhibit installed and, after disarming the system the car doesn't start, there are several steps to take to ascertain the problem.
Begin by using a voltmeter or, low voltage testlight and test the starter wire at the ignition switch. Turn the key to start and test for voltage. If you do not have 12 volts on the starter wire at the ignition switch when turning the key to start, you either have no power (battery or fuse) in the vehicle or, your ignition switch is bad.
If you have 12 volts at the switch, move your test light to the other side of the starter kill and test for 12 volts. If there is no starter kill, move your tester to the starter relay under the hood. If there is no power coming from the relay, you have found your problem. If you have power coming from the relay to the starter then test the starter when turning the key. If you have power at the starter when turning the key you have found you problem. If you have no power going to the starter when turning the key then there is break in the line.
Jan 20, 2013 | Vehicle Parts & Accessories
How to deactivate kill switch?
Locate the Autopage module, interupt the yellow wire with a toggle switch. This assumes you are not planning to remove the entire system.
Jan 29, 2012 | Autopage Vehicle Parts & Accessories
Not crank
Hi, When you turn the alarm off you have to try to start with the alarm switched on then it should start. Suggest you get the alarm removed or by-passed if you need alarm then purchase another one & fitt but remove all old alarm wiring fully. Please leave me feedback, Malcolm Campbell.
Sep 23, 2017 | Infiniti J30 Cars & Trucks
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
I have a 2003 hyundai sonata and i dont have the remote for the stock alarm. My alarm keeps going off and my car wont start. I bought a new battery and even tried the key in the door still no luck.....
The 2003 Sonata is equipped with a 'starter KILL' burglar alarm system with disables the starting system (using a N/C 'contacts' configuration instead of a N/O contacts configuration). N/C=Normally closed, and N/O=Normally open contacts. When the alarm goes off with a MY Sonata, the only way to DISARM it is with the key fob (remote) originally programmed for it (unless you purchase a new remote & have it programmed for the vehicle at an authorized Hyundai Service Department). NOTE: So long as the keyless entry & burglar alarm system is functioning/operating normally, the alarm will keep going off and the STARTER KILL function will still prevent you from starting the vehicle. One option is left without purchasing a new remote and having it programmed.
1. When the alarm goes off, get into the vehicle and insert the ignition key into the ignition.
2. Turn the key to the 'RUN' position (NOT the ACC position) and wait for the alarm to STOP (usually about 3 to 5 minutes).
3. The engine should then start using the ignition key.
If this procedure doesn't work, the problem will need further diagnosis by a qualified/certified Hyundai Service Technician.
Hope this helps
Aug 27, 2011 | 2003 Hyundai Sonata
My car doesnt lock the door when its armed but opens when disarmed
one possible solution is check the wires connected to door lock and starter module , look at the starter diagram and trace the related wire, this wire need to be soldered again
Mar 01, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
Why does the alarm in my car go off when I try to start it with the remote car starter?
If this is the vehicle's factory alarm that is being triggered then your factory alarm must be disarmed prior to the remote starter sequence. The Autopage unit has a factory disarm wire available for this purpose. When the alarm triggers again try turning the key in the driver's door to see if there is a factory disarm wire available in the vehicle or if the factory alarm is RF disarm only. If it is the after market alarm that is being triggered then you made need to decrease the sensitivity.
Nov 23, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
I have a 1998 Toyota camry 4 cylinder and it wont start i changed the battery and got a new starter and it wont turn over at all thing is my alarm wont turn off either what can be the problem and how do u...
try this
Open hood ensure new battery is disconnected.
Open main fuse panel cover under hood and remove horn relay (so you don't have to listen to the horn).
Use the key to lock the drivers door.
Connect the positive battery terminal.
Connect the negative battery terminal (security system will now activate, hazards lights will flash and horn would be going off if the relay was not removed).
Use the key to unlock the drivers door.
Get in, close drivers door.
Use the key to start the engine.
Security system will deactivate.
Get out of vehicle, reinstall horn relay, replace fuse panel cover, close hood.
Dec 27, 2017 | 1998 Toyota Camry
Car won't start
The problem is in the starter system circuit(s). Check/inspect the condition of the battery cables & connections to the starter & grounds - replace/repair/correct as needed. Next, inspect/check the starter clutch pedal position switch - repair/replace as needed. Next, starter relay operation and connections. Of course, inspect/check all wiring connections. The burglar alarm relay is 'normally closed' contacts unless the alarm is activated - in which case the alarm must be 'reset' (deactivated) to re-close those contacts. You mentioned front end collision damage - definitely inspect all wiring there - repair/replace as needed.
Dec 11, 2008 | Hyundai Motor 2003 Elantra
Vehicle Parts & Accessories Logo
175 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
