Question about Kenmore Dryers
Kenmore dryer wont start tab broken
Dryer wont turn on when pressing the start button, was working fine other day. Checked power and outlet is fine. Noticed that the tab on the top right of door is broken. Can this be the cause? If so, can I replace it myself?
  • Kenmore Master
  • 8,220 Answers
Yes that is the lever for the door safety switch. It can be fixed easily,
I have repair pictures and home made video on Kenmore dryers HERE
Posted on Dec 02, 2012
Kenmore 89722 dryer
check the micro switch on the door . worn door hinges/broken door hinges will not activate the micro switch and so the unit will not turn on as it thinks that the door is still open
Nov 11, 2013 | Cars & Trucks
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 30, 2011 | Kenmore Dryers
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
My Roper dryer Model #RGS7648E will not start
Here is a tip that I wrote that will give you a list of things to check...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Roper RGS7648E Dryer
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Jan 04, 2009 | Maytag HYE3657A Electric Dryer
Kenmore gas dryer won't start.
Hi!!1 You have a shorted thermal fuze on the dryer..The thermal fuze is located in the back of the dryer its white and oval with 2 wire leads..replace it and you should be fine..good luck..
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
301 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
