Question about Conair Cuisinart SmartPower Deluxe Duet Blender/Food Processor
Cuisinart blender on button red light keeps flashing and won't work
PHONE # OF PARTS DEPARTMENT OF CUISINART.I HAVE A CUISINART BLENDER SR#70604 MODELE SB5600
Is this regarding the 4 rivet blade recall as that is a different kettle of squirrels.
Parts & Accessories - Cuisinart.com
https://www.cuisinart.com/parts/
  1. Cached
Cuisinart Parts for Kitchen Products. ... Water Filters- Fits all Cuisinart water filter holders. Keep your water filter current so you can make pot after pot of delicious ...
Contact Us - United States - Cuisinart.com
https://www.cuisinart.com/support/us/
  1. Cached
To best serve you, our Cuisinart Representatives are available to answer your calls between the hours ... Cuisinart® Customer Service ... Marketing Department:
PARTS DEPARTMENT OF CUISINART Google Search
Dec 29, 2016 | Cuisinart Blenders
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
My Cuisinart soup maker keeps switching off
How you removed the bottom? Screws are so deeb and I cant see what screwdriver I have to get.
Nov 20, 2012 | Cuisinart SSB1U Soup Maker
Ginny's blender lights keep flashing
you have to have the top part on before you turn on the blender
Sep 09, 2012 | Blenders
I tried to blend large piece of the frozen mango. It won't move and I continue trying . I smell little burned and the machine wont move again.
It sounds as if the motor has burned out. You may need to purchase a new blender or send it to the manufacture for repair if it's still under warranty.
Jul 14, 2011 | Cuisinart Blenders
I have the red Cuisinart BFP-703 SmartPower Duet Blender/Food processor. I turn it on and press and of the buttons and it does come on. What should I do?
if you over loaded these machines there is a thermal fuse one time shot will blow . it is not resettable , you can buy them @ Radio Shack 8 amp should do fine . it might be stamped with the rating value too. need a test meter to check component very small .187 diameter & .750 length apx
Mar 14, 2010 | Cuisinart Blenders
My cuisinart spb-7 blender won't spin
How do I replace the blender blade driver clutch? I have the part but do not know how to get it in.
Jun 13, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
Apr 15, 2009 | Cuisinart BFP-703CH Chrome Blender
The red light on my blender keeps flashing but when i press any other buttons it just beeps twice and does nothing.
inside the jar ring base (turn it upside down) you will see little white tabby things in the slots, at least one of them has to be lined up with the 2 small grey contact points on the base of the blender.
I had this same problem!!
you can contact me at jureed@rochester.k12.mn.us
Julie
Jan 26, 2009 | Oster 6700 Work Top Blender
Conair Cuisinart SmartPower Deluxe Duet Blender/Food Processor Logo
246 people viewed this question
Top Conair Blenders Experts
eyecam
Are you a Conair Blender Expert? Answer questions, earn points and help others
