Question about Plumbing
The fluid mast dual flush works but won't stop running. The flap does not low after flushing
  • 7,627 Answers
Wrong category
Posted on Dec 18, 2012
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
I have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Why do you want to change it out just because it doesn't take paper out ? The problem is in your trap. Don't change it unless you just want to. I don't think you can change it over anyway due to design differences.
Feb 23, 2013 | Home
Won't shift when cold
With the car warmed up and running, check the transmission fluid level. It may be low or needs flushed.
Sep 16, 2012 | 2004 Mitsubishi Endeavor
Fluidmaster Dual Flush Valve S2DBL won't flush.
Fluidmaster S2DBL Dual flush valve - would not flush
The dual flush wouldn't work at all. So I slid the lid off part B (lever mounting base) and found the ball end of flush cable was not in the mating hole on lever arm. With needle nose pliers I pulled and pushed the ball into the hole and slide lid back on till it snapped. Snapped B to C (handle) - problem solved!
RAP
Jan 29, 2012 | Home
After flushing, the toilet keeps running. However, if I turn off the water supply, and then turn back on, the toilet stops running until the next time it is flushed. Toilet makes a
It could be the type of flap you are using. I would suggest you try a different shaped flapper (a cone would work best) and if that doesn't do it, put a new kit into the unit, because it could be that the float system is sticking causing it to continue running.
Jan 10, 2012 | Toto Carlyle One-Piece Toilet Toilets
Toilet running and won't stop.....it keeps running into the little overflow tube
When water goes over into overflow tube then that means 2 things.
The rubber flapper at tank bottom is good and does not need replacement at this point.
That leaves 2 possible problems.
1) The flush valve needs to be adjusted so water turns off sooner.
Flush valve lets water into the tank.
For example if you have a float ball on end of brass rod, just bend the brass rod so the float sits lower in the water.
If you have the 'fluidmaster' then a float rides up and down with water level. There is a metal rod with a metal clip. Squeeze the metal clip and move it downward on the metal rod.
2) If water will not turn off after adjusting flush valve, then replace flush valve.
Local hardware store sells the part and can help with instructions.
You need a crescent wrench or large adjustable pliers.
Plumber can also install the flush valve.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plunbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
Not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
Oct 29, 2008 | American Standard Flowise 2480.216.020...
Plumbing Logo
24 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
