Question about Onkyo Tx-88 Stereo Amplifier Tuner Tx 88
Onkyo tx-88 will not power up
Fuse ok
  • steve Dec 02, 2012
    It only makes common sense to take it get it fixed. I want to know what the problem might be so I am able to fix it myself.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Internal problem with it, Take it in to be repaired,
Posted on Dec 02, 2012
robotek
  • 1512 Answers
SOURCE: onkyo tx-ds676 dead no power up
power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Posted on Dec 10, 2007
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
SOURCE: Onkyo TX-SV525 A/V Receiver The fuse by the
The same rating fuse will work as long as the "Ampere" side is the same. The "Voltage" of the fuse determines the input Voltage that will be allowed. As long as you are sure that the input will only be 120V the fuse will work properly but I would recommend using the same Voltage and Amperage of the original fuse since it may fail again. Given that information if it does blow again I would recommend taking it to a specialist. A 3 Phase fuse is only available to 3 Phase inputs (480V). Unless you live in a large compound your house doesn't have that type of capability.
Posted on Sep 17, 2009
  • 137 Answers
SOURCE: Onkyo TX-SR701 Digital audio port stopped working
you may want to try a factory reset by pressing and holding vcr1 button while pressing the power button. do this with the unit on. It will reset back to factory default. so any saved setting will be lost and you will have to set again to your settings.
Posted on Apr 18, 2010
  • 137 Answers
SOURCE: Onkyo TX-DS898 Memory Loss
THEY USE A MEMORY CAP.ITS LOCATED ON THE MAIN PCB ASSEMBLY, REF. C7701 ONKYO PART NUMBER IS 3000078/ WITH THE UNIT TURNED OFF MEASURE THE VOLTAGE YOU SHOULD HAVE APPROX 5V IF NOT THE CAP IS BAD. ALSO MEASURE WITH UNIT ON AND YOU SHOULD ALSO MEASURE 5 V IF NOT THEN THE SUPPLY VOLTAGE GOING TO THE CAP IS BAD.
Posted on Apr 19, 2010
Onkyo tx sv727 -when you turn it on it goes haywire.The unit will make a constant clicking sound.As if it was a car signal light turner. help
The first Poff is ok. But the second Poff2 is missing.
Check the power output for Poff2. There is a fuse broken maybe.
Jul 23, 2017 | Onkyo Audio Players & Recorders
Onkyo tx-ds787 6.1 channel receiver won't turn on? no light nothing!
Check the fuse inside the unit. If there is no power lights, the power supply may be bad - the fuse is located in the power supply. Check you wall outlet, too.
Dec 04, 2010 | Onkyo TX-DS787 Receiver
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
Receiver does not power on. standby not on either. receiver is the onkyo tx-sr501
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Apr 26, 2009 | Onkyo TX-SR501 Receiver
Onkyo tx8511. Receiver working fine, power went out
Is channel B switch turned on? If so turn it off .
Feb 27, 2009 | Onkyo TX-8511 Receiver
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
Display on receiver no longer visible
from display power by ac voltage 5.6vac pins 1and2 and 65and66 should be from power transformer there is no fuse for this display light
Nov 10, 2008 | Onkyo TX-DS595 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Onkyo tx-ds676 dead no power up
Nov 24, 2007 | Onkyo TX-DS676 Receiver
Onkyo Tx-88 Stereo Amplifier Tuner Tx 88 Logo
64 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
