My logik tv is saying no services, select the
My logik tv is saying no services, select the services menu. I've tried auto and manual tuning but no luck.
  • 30 Answers
SOURCE: Hyundai hqp-421*r/501*r
Hi gomaniac,
May i know how your plasma tv fuzzy as? Can you provide the photo to easily us measure it? May be you can go here to let me know which type of display problem are you appear?
http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html
Posted on May 10, 2008
  • 5 Answers
SOURCE: tv manual
Most likely this is a generic TV made either for the company you bought it from or a Manufacturer having it made for them. You can usually compare the TV to other brands and find one that is identical just made by someone else
Posted on Aug 31, 2009
valiantma595
  • 176 Answers
SOURCE: can not tune the tv
My dear friend. A TV is a TV and TV's are many and varied. If you stated the model and what it exactly does, maybe I or other people could help you instantly. But since you have said little in relation to TV tuning, then expect a few guys to help you. But allow me to give you a hint that applies to almost all flat panel TV's, ok? Right. On every TV there is a MENU that gives you many options. First you need to press a button on the remote that displays component connection channels and TVincoming signal type. Since I don't know what brand of flat panel TV you have, I can only ask you to find and press the button on the remote that displays on TV screen the following component channels, that is DVT, AVT, Component 1, Component 2, HDTV1, HDTV 2, HDTV 3 and so on. Apart from DTV and ATV, from Component 1 to HDTV 3, these additional channels are for DVD players that also have HDTV outputs and BlueRay players and or Audio devices. If yout TV hasn't got as many channel input, then ignore this part. To tune your TV you have to first press the butoon on the remote to activate the onscreen channel as above, then scroll on DTV or ATV and, depending on whether you have Digital TV in your country or the standard high resolution Analog TV. Lets say you have Digital NTSC format TV system, select it and then press ENTER on your remote. In the menu you find and click SCAN. Depending on where you are, the TV will begin scanning all frequencies in your territory and possible interstates if the modulator is powerful enough to pick up weak signals. Most TV's have an inbuilt set-top box that boost the signal to give you a crystal clear pic. Now, after pressing SCAN, the TV reaches a signal with a clear pic, all you have to do is recognise the channel that comes in view. The instructions on how to save that channel are on screen and then you can configure it as, say channel 4, if the channel that appeared is channel 4, if not, try and recognise what channel had appeared and then configure it with a number, so when you press that number on the remote it will be the same channel you had stored in the TV memory. After you have done this, press scan again and it will scan to the next channel. Once the scanning recognises another clear signal and it is as clear as a baby's face, you have recognised the new channel. Try, find out what channel it is by looking at the screen, there is usually a visible TV station name or number embossed on the lower corner of the screen, once you know what station that is or what channel number it is, configure that number and press ENTER (save) button. Do the same with the remaining channels. Later I will tell you how to skip unwanted blank channels that usually have no signals but snow and lines, or have faint signals that can only be boosted with a TV booster available from reputable TV retailers, or install a bigger more powerful antenna.
Reagards.
Mike
Posted on Oct 06, 2009
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
  • 1340 Answers
SOURCE: Tv appears to be stuck in auto-detect mode
All I can suggest is press down and hold your menu button on the remote and roll around in circles.Also try it with the menu button on the TV.It definitely sounds like it is being pushed down enough to be stuck.If that does not work please write back and in the meantime I will research it a little further.Bought in March huh?90 day waranty too I bet?How long has this been going on?If it does not work,I am also providing a link to Samsung to contact them.You will need probably model number and serial number.If you have the receipt,registered it,or have a credit statement to show when you bought it,and you are really persistent,they will usually do something about it.Samsung is supposed to be one of the best TV's too.I am surprised by this issue.Good luck!
http://www.samsung.com/us/info/contactus.html
Posted on Jul 29, 2010
My Logik freeview box has will not tune some channels - most are fine. What can be done to fix this?
Usually that is caused by poor signal strength or a faulty tuner inside the receiver. Replacement boxes are only £18 upwards.
Nov 23, 2014 | Televison & Video
I have tried to tune my tv but its still not going even when i put the cable in the right place.! it just shows no channels at all.! what can i do?
In your "Channels" menu, you should have the option of "auto tune". Once you've plugged in your antenna, cable cord, select this option. Before doing so, unplug your tv ONLY and let it set for about a minute. Plug it back in, turn on, go into Channel Menu and select the "auto tune" option. This may take a while, as newer tvs have several hundred channels. This will auto tune your tv to the channels received through your selected device\cable. You may consult your user manual for further assistance. I just did this with my tv a couple weeks ago and its very simple. You will also be able to "delete" channels that do not come in well, or not at all i.e. The "ant screen" etc.
Aug 29, 2014 | Televison & Video
All channels permanently deleted accidently, can I restore them
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
Nov 10, 2013 | LG 32LD350 32 in. LCD TV
I gone on holiday and we've taken our small
If there is a Menu button on the front of the TV, you can enter its user modes, to select auto tuning feature.
Jun 16, 2013 | Televison & Video
Replacement remote control not working on TV
What is the brand name of remote control you bought?
Jan 21, 2013 | Televison & Video
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
When I switch on my Logik TV, the screen now says "NO SERVICES - select the Services Set up menu" But there is no such menu anywhere, and I cannot exit this screen! Help, please IAN
This also happened to me, but the problem is that your attena cable has accidentally dropped out of your TV. Slot it back in and then auto tune again. Hope that helps!
Nov 12, 2010 | Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Televison & Video Logo
337 people viewed this question
Top Televison & Video Experts
