Question about Electric Garden
I have a craftsman pressure washer model 580.752020 used it yesterday worked great. tried to use it today and it wont come on .water is coming out normal but no motor. light is on , on the plug but nothing happens
  • 156 Answers
SOURCE: Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Posted on Jul 06, 2009
  • 10865 Answers
SOURCE: honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Posted on Apr 12, 2009
SOURCE: craftsman model 580.752020 electric pressure
turn off water and machine electrics.
remove high pressure hose from front of machine, this may be tight if there is still pressure in the system.
turn on water, when water comes out of machine hose outlet turn on machine. does the machine turn on and water flow increase, if so you probably have a blocked lance jet or trigger.
remove lance extension if fitted and fit hose back to machine, try again. If its ok then this proves you have a blocked lance jet, maybea poke about with some stiff wire will free the obstruction.
If this doesnt bring on the machine you probably have a jammed pressure switch on the pump.
this pressure switch turns on the pump when the trigger is pulled and switches the motor off when the trigger is released.
hope this helps.
Posted on Jul 18, 2009
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
  • 5603 Answers
SOURCE: modeL 580752610 CRAFTSMAN 2600PSI
This is the typical problem when the water admitance valve sticks. This valve admits more water to the pump when the pressure drops when wand is triggered. When pressure increases, water is blocked. This is the way they regulate the pressure. The valve is in a bore, usually crossways to the axis of the shaft of the pump. Disassemble the valve noting how the parts go in. Clean the bore with crocus cloth on a dowel rod. Replace all the O rings on the valve spool. Lightly lube the spool with plumber's grease and reassemble.... Good as new! You can often buy a kit of O rings for the valve. They must be EXACT right size. This is normally a one-half hour job.
Posted on Apr 15, 2011
Craftsman 2200PSI pressure washer, part #580.752700 dies when trigger off.
NEVER start an engine on a power washer with pump attached. You will damage pump and get no or very little pressure. Replacing pump only fix. Pump for this washer about $49. Check spring on carb for throttle open/close
Jun 10, 2016 | Craftsman Garden
Electric pressure washer wont start
Gail, check the cord/plug for any sign of breakage, probably either switch has gone bad or motor faulty, have tested by a small appliance repair/ vacuum repair shop as they are usually the most reasonable priced.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 12, 2016 | Greenworks 1500 PSI 1.3 GPM Electric...
Pressure washer only works if you crank it with pressure handle open , then works great if you let off it builds up pressure . and no water will come out when handle held fully open , bleed off pressure...
Hello..the unloader valve on the pump where you attach your water supply and your pressure outlet hose is the problem.There is a spring relief valve that is most likely frozen and not allowing the water pressure from the pump to circulate within itself.They range from 60.00 to 150.00 depending on your make and model.
Aug 19, 2011 | Briggs & Stratton Pressure Washer...
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Garden Logo
103 people viewed this question
Top Electric Garden Experts
Steve Oakes
Mike Squire
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
