Question about Maytag Neptune Washer
Codigos para lavadora maytag neptune MAH5500BWW serie A2982915CE
Mi lavadora le sale el codigo ''LO''como puedo hacer para.normalisarla, no tengo el manual.
4 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Posted on Jul 17, 2009
TheMobilian
  • 8220 Answers
SOURCE: mi lavadora no termina el
Maytag washer notes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: la lavadora no funciona sale codigo Lr
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $#$Er
Posted on Oct 01, 2010
Manual de codigos para el control universal taika TK DVD
Tengo el control remoto taika tk-403 y necesiti el codigo y como configurar para un vsonic
May 30, 2014 | Televison & Video
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Como programar mi reciver onkyo con el control remoto de dishnetwok
Acolonpr, su pregunta me llamo la atencion por lo cual se me hiso interesante! Lo que le recomiendo es que siga este link http://www.dishnetwork.com/SupportSection/remote-setup para instrucsiones en como hacer esto. En esta pagina hay diferenetes opciones de recividoes. Usted puede encontrar su modelo de recibidor chequeando el numero localizado en la parte de enfrente de su recebidor a mano izquierda. Si los codigos apropiados y rececibidor para su contol no son encontrados usando esta pagina, puede intentar reprogramar el control buscando el codigo.
Dejeme saber si necesita ayuda adicional sera un placer ayudarle!
Espero que esto le ayude!
Apr 20, 2011 | DISH Network IR Remote Control
Como desbloqueo mi ipod a1285 me pide un codigo de 4 dijitos y no lo se
no se que hacer porque mi Ipod model a1285 se me bloqueo le di y en la pantalla se me puso un candado y me pide codigo ke no tengo ke hago porfavor?
Mar 01, 2011 | Apple iPod nano
Mi honda accord me pide un codigo para desbloquear el radio como lo soluciono?
buenas tardes el estereo de mi accord 2005 se bloqueo y en el U sale 1222 y L 7575 pero solo trae del 1 al 6 como meto ese codigo
Feb 23, 2011 | 2001 Honda Accord
TENGO UNA CR-V 2003 Y ME PIDE CODIGO EL RADIO PARA FUNCIONAR
tengo un c r v honda 2003 le cambie la bateria y haoro no tengo el codigo
Jun 01, 2010 | 2003 Honda CR-V
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Washing Machines Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
