Question about Sewing Machines
Bernina Activa 230 - how to fix tension
How to adjust tension
bargainbox
  • 1388 Answers
SOURCE: how do I know which tension to adjust?
Are you sure that a stitch is being created each time, or is it missing some....
On a scrap, sew a zigzag to ensure that at least the stitches are being formed, if not, or missing some, look to timing.
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
  • 13 Answers
SOURCE: hot to thread a bernina activa 240 sewing maching
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on May 27, 2009
Mongo32
  • 111 Answers
SOURCE: I have a Bernina Activa 130. The bottom threads
bunching threads bunching means that upper tension or threading is wrong
Posted on Jul 08, 2009
  • 14 Answers
just visit www.janomestuff.com
Posted on Sep 17, 2009
My fabric is puckering. I have an activa 230. I know it is a tension problem. I can't find my manual so I can't figure out how to fix it. Thank so!
How to Achieve Ideal Sewing Machine Thread Tension Threads
Understanding Thread Tension Threads
Here's the manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-230
Interestingly, I just went through all sorts of gyrations today because the fabric was pulling up like it was being gathered. Turns out after I'd tried nearly everything, the thread had slipped down the thread spool and wrapped around the spool pin. Problem fixed...
Oct 19, 2017 | Sewing Machines
My reverse sewing tension is to tight on my Bernina Activa 220 Sewing machine. Forward is fine. How can I loosen it without affecting the forward tension.
tension is set by the adjustment and is not affected by material direction
it is only the walking foot that changes direction and not the sewing action
discus this problem with a service center as there may be a service issue
Aug 11, 2016 | Bernina Sewing Machines
Why won't my Bernina Activa 230 P.E. start when I turn it on?
it sounds like a computer problem. I suggest taking the machine to some other repair shop and see what they say.
May 05, 2014 | Bernina Sewing Machines
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Bernina Activa 240
There is also a tension adjustment on teh bobbin. It's just a little screw. Turn it about 1/4 to 1/2 turn and try again. Adjust as needed a little at a time.
Oct 19, 2008 | Bernina Activa 140
Bernina Activa 135
either the bobbin thread is not in the lower tension or the lower tension is too loose or the top(upper) tension is too tight.
sewman7
May 20, 2008 | Bernina Activa 130
Operating manual
Unfortunately this is a purchase site. The closest I could get would be for an Activa 220 230 240 . You can download the manual.
Check the picture on no. 7 and see if this isn't your machine.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Hope this helps. Luck!
PS Sewusa is no help.
Mar 01, 2008 | Bernina Activa 130
Owners manual
Dec 20, 2007 | Bernina Activa 130
Sewing Machines Logo
201 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
