Question about BaByliss PRO Nano Titanium Hair Dryer
Blow dryer keeps sutting off during use
My blow dryer keeps shutting off during use. I know it's not the cord i think it's a heating element because it happens when i use the diffuser to straiten my hair. I lost the freak'n warrenty and like an ***, i forget to fill it out and send it in. I love this dryer and it cost me like 80 bucks!!! Is there anywhere i can take it to get fixed or a part that i can buy to fix it?
    New Friend:
  • 49 Answers
The warranty is worthless. But no matter. It sounds like the 'thermal breaker' was tripping while you were using it. If it would come back on after it cooled down for a few minutes, that's it. There's a little switch inside that trips open if the dryer gets too hot. Once it cools, the switch resets itself. All hair dryers have them, I'm sure it's a safety requirement.
Glad you got it fixed though!
Posted on Mar 02, 2015
2 Suggested Answers
SOURCE: broken hair dryer
I got a friend to fix it.
Posted on Jun 24, 2009
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
No heat , drum turns and wont shut off
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 05, 2010 | Whirlpool LER4634J Electric Dryer
Electric Dryer, heating el works, exh not blocked, clothes no dry
double check your element temp t-stat and recheck continuity on element. I have known them to work but have shorts in them
Apr 09, 2009 | Crosley CDE6000 Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer wont shut off and gets no heat.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Thermal fuse
Wiring
Dec 23, 2008 | GE DBSR453EBWW Electric Dryer
Thermal fuse keeps blowing
Good Afternoon,
Unless there is something restricting the ventilation I think you are having a problem with the heating coil staying on too long. If that is the case, one or more heating sensors are bad. Let me know if this helps and thank you for using FixYa!
Nov 25, 2008 | Amana NDE2335AY Electric Dryer
No heat
If there is no heat during drying cycle, it is usually either the heating element, or a thermal fuse.
See the following suggestions from repairclinic:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 19, 2008 | Splendide 2000S Vented Washer/Dryer
Broken heater during the dryer cycle
Heating element
Thermal fuse
Wiring
Feb 17, 2008 | Equator EZ 3710 CEE / W Ventless...
BaByliss PRO Nano Titanium Hair Dryer Logo
896 people viewed this question
Top BaByliss Dryers Experts
paul
paul
Tom Chichester
Denkichu
Denkichu
Are you a BaByliss Dryer Expert? Answer questions, earn points and help others
