Question about Microsoft SQL Server 2000 Standard Edition for PC
40002 37000 microsoft odbc-sql server driver cannot open database request
Error can not open database login fails
2 Suggested Answers
  • 17 Answers
SOURCE: Error while trying to login to database - Error establishing sokcet.
this page says you need service pack 3:
http://www.myeclipseide.com/PNphpBB2+file-viewtopic-t-7813.html
and here is Microsoft's information
http://support.microsoft.com/kb/313178
Posted on Jan 22, 2008
Which database can I use with ColdFusion?
ColdFusion supports ODBC-compliant databases. With Net Nation's ColdFusion plans, you can use a Microsoft FoxPro, Microsoft Access or Microsoft SQL Server database. ColdFusion supports both DSN and DSN-less connections.
Oct 09, 2014 | Oracle 10g Database Standard (ODBSEONUPP0)
Java.sql.SQLException:[Microsoft][ODBC SQL Server Driver]login failed for user 'Sony-PCSony'
Either the user Sony-PCSony is not having login rights to the SQL server or the SQL server is in windows authentication mode and not in mixed authenticatin mode.
May 24, 2010 | 1999 Daewoo Lanos
I am trying to connect to a SQL Server 2005 DB from Visual Studio
You must create an ODBC connection to your SQL database in the Windows Control Panel. Than you can call your ODBC connection via Visual Studio 2005. You can also create a DSN in Visual Studio 2005 and reference in that way. You will not be able to connect to an MDF but instead you have to connect to the SQL Server Service. Of course the username you use to connect must have access that will be created on the SQL server.
Apr 13, 2009 | Microsoft SQL Server 2005 Standard Edition
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
ODBC
give ur add i want to check it out.
Aug 26, 2008 | Microsoft Windows Server Standard 2003 for...
Install A4 tech PK635 M web cam without cd installer
how to install a4 tech Pk camera webcam without using cd installer
Apr 28, 2008 | A4tech PK5
Jan 03, 2008 | Microsoft SQL Server Standard Edition for...
You have a named instance installed with dynamic ports configured (default) named "local". In this case, the connection string would be localhost\local instead of local:1433. You could alternatively configure the service to use a fixed port and then connect using just localhost:. With dynamic ports, you would have to resolve the name of the service through SqlBrowser, which should be running
Nov 03, 2017 | Microsoft SQL Server Standard Edition for...
The sound
You can visit the following link, make appropiate selections and download the drivers for sound: http://support.fujitsu-siemens.com/com/support/downloads.html cheers
May 02, 2007 | Fujitsu Siemens AMILO D-7830 Notebook
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
See all Microsoft SQL Server 2000 Standard Edition for PC Questions
Microsoft SQL Server 2000 Standard Edition for PC Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
