Question about Sony ACID Pro 5 for PC
Timing problem!! help needed badly!
People, im having timing problem with my acid pro.. like, first i record the guitar and then when i record the vocals on it , they dont get in sync! the second layer is slightly ahead in timing with the previous layer though when recording the second layer, i record with perfect timings! at first it used to be perfect but then i formatted my pc due to some virus, and then when i re0installed acid, since then im having this problem..ive tried formatting my pc again n again n installing the software many times but this problem is there..i changed my sound card too but the problems remains unresolved..please help me as i need to record songs..
  • Anonymous Feb 21, 2009
    Recording timing is off and not only that but it records all the other tracks open in the file
I had that problem. I fixed it by adjusting my Sample Rate and Bit Depth in Control Panel (Sound) to match the Sony Acid Program. When in Acid, hit the record button and a window opens up. At the bottom of that window you will see 'Attributes' and next to it you'll most likely see 44,100 Hz, 16 Bit. Your computer should be set at these values to record in sync.
Posted on Oct 11, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
Your solution is to delay or speed up the sound that your running thru to your computer. The reason why they put user recording latency under the options then preferences then audio settings is not because this never happens or isn't know about. If your sound is too late in the track you have to re-record the track with a higher number try about 125-160. A hint is to play some notes to the beat, check to see that you are in time, then record what you are planning to record.
Posted on Feb 07, 2009
I have a Fostex DMT-8vl 8 track digital recorder. Can I dump the tracks to Acid Music Studio 7 or Acid Pro 7 to save what I recorded in the Fostex 8 track, and will it go into seperate tracks? Thanks...
You can copy. You cannot just dump the file data. Unless you have an audio interface with multiple inputs, you can only copy 2 tracks at a time. Also, to sync the timing you'll need a midi port on the computer. Then you make the computer the "master" and the Fostex a "slave" device.
Jul 21, 2010 | Sony ACID Music Studio 7
Recording with sony acid 6.0
my vocals are off beat when i record why is that.
Mar 29, 2009 | Sony ACID Pro 5 for PC
Missing manual for guitar pro tracks 3
Here is a URL i found with a manual that might help?
Link
Mar 16, 2009 | Cakewalk Guitar Tracks Pro 3 for PC
Problems recording with Sony Acid mucic studio 7!
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
Sep 30, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Slow Playback
Sounds to me that the computer is way out of date. Chances are the computer doesn't have enough processing power to support what you're trying to throw at it.
It might help stop/uninstall all other programs running at the same time to give Cakewalk the best chance of working.
Nov 15, 2017 | Cakewalk Guitar Tracks Pro 2 Classic
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Help
need pre amp with it boost ya and to get it in sterio way should be are u running it direct in usb port and u have usb 2.0 outlets corect
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
PLAYBACK PROBLEM
need to know if you use headphones while recording, if not it could be feedback from your monitors or even the phones.reasons phones too loud or mic gain too sensitive.
May 28, 2007 | Rode NT1A Professional Microphone
Recording in Acid Pro 5
Are you plugging the instrument directly into the computer? If so you only have mono jacks from your bass, guitar so on and so forth! So in channel in only one to record! Try using a stereo microphone and record pointing at the amp. That way you will get stereo through your device. If that is not the problem make sure that the settings on the Prosonus is set to output stereo. And for most check all your plugs to make sure they are stereo inputs and outputs.
Sep 05, 2006 | Sony ACID Pro 5 for PC
Sony ACID Pro 5 for PC Logo
596 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
