Question about Sansui Audio Players & Recorders
How can i connect my pc to a sansui R-950AV receiver and then to speakers ?
I need to connect the pc's audio output (3.5mm jack ) to the amplifier and then to some speakers . which section should i choose ? aux , tape , or phono ?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Connect it to the (Auxillary) Jacks,
Posted on Dec 02, 2012
SOURCE: No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Posted on Feb 17, 2008
SOURCE: I have an old Sansui au999 amp
you can go about this many ways.depending on what you have to work with.are you useing a satilite or cable box?if so assuming they have audio/video out just send the audio to the amp and the video cable to the tv.u could use the aux or the tape in.just put the dvd in the other input aux or tape in.dont matter which.if you dont have a cable box your tv must have some kind of audio out to run to the amp.it can be a rca out or simply a headphone jack.you will need a headphone jack too rca plug cable if you have a headphonejack on your tv.hope i could be of help.
Posted on Jan 05, 2009
SOURCE: muffled sound from speakers when connected to laptop via amplifier
You need to buy an analog to digital converter box if you want to get superb sound quality from your computer.
Posted on Mar 10, 2009
  • 128 Answers
SOURCE: I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Posted on Jan 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Posted on Feb 21, 2010
Testimonial: "Thank you for your help to an electronics layman!"
How to hook up the subwoffer
There are several methods, depending on the the types of 1)inputs on the subwoofer and 2) outputs on the amplifier (aka receiver). You can only use the type that is on BOTH.
Most sub woofers have "line level" inputs (they are the RCA phono style jacks or other style jack) that are marked "In" or "Input" and may have speaker level input & output terminal that accept speaker wires.
Amplifiers or "amp" all have speaker level outputs and many also have jacks that are labeled "Subwoofer" or "LFE" (low frequency effects) Output. If both your sub and amp have the "line level" jacks, then all you need to do is get a cable that is long enough to connect the two together, and then enable the low frequencies to be sent to the sub instead of the normal speakers in the receiver's set up menu. Done!
If you have only a speaker level connections common to both the sub and amp, you'll most likely need to disconnect the Main front L and R speakers from the amp and connect to the sub's Speaker Output terminals - and connect a couple of new speaker cables between the sub's Speaker Input terminals and the amp's Main front L and R terminals.
If you don't understand completely, provide the make and model of the amp and the sub, and I'll be able to clear up anything that isn't clear.
Mar 05, 2015 | Audio Players & Recorders
The sound wont work with this tv as its connected to the pc. just bought the tv today, tv's model is Sansui SLEDVD244. plz halp me yall :-(
You might have to download and or install the correct drivers. A lot of stuff comes with the install for the needed drivers. Might it of had a cd with it.
Mar 31, 2013 | Audio Players & Recorders
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips Audio Players & Recorders
Can't get sound to come from speakers with tv only the radio
You didn't give the brand and model of your TV, and I can't try to find a manual and see what kind of AV connections it has available. So here's some general information.
Many TV sets only have input jacks for external sources like DVD players or cable boxes. When you select an external source, or use the set's internal tuner for TV programming, the video and audio play through the TV. The trouble is that if the set has no audio output jacks, there's no way to get a sound signal out. The TV accepts only inputs
When the TV is part of a home theater system, most people use it just as a video monitor. All AV sources connect to the receiver, and audio is sent from there to the speakers. A video output from the receiver goes to the TV so you can see the picture, and the TV's speakers aren't used. If you have a cable box, FiOS set-top box or satellite receiver for your TV channels, they connect to the receiver too, since they're just another external source.
This doesn't work if you rely on the TV's internal tuner for TV channels, though. This might be the case, for instance, if you have a cable system where a converter box isn't required and your cable connects right to the TV. When you're watching regular TV, then, the sound comes through the set's internal speakers. If there's no audio output available on your TV, that's your only option.
As I said earlier, many TV's have only audio inputs. But some have audio output jacks as well, so the sound has a way out. If yours does, you can connect them to one of the inputs on the home theater receiver. Then when you select that input you'll get the TV sound through the speakers connected to the receiver. Depending on the design of the TV, you may need to leave the TV volume turned up. Some sets have outputs that are follow the TV's volume setting. On others, the output is an independent fixed level. Then you can turn the TV volume down and use just the receiver's speakers if you want.
Check the connections available on your TV and look for a set of "audio out" jacks. Your TV's owner's manual should have a section explaining how to connect it in different ways. If you need a copy, most manufacturers have manuals for download on their website.
Good luck with your sound, and thanks for using Fixya!
Jun 17, 2011 | RCA Audio Players & Recorders
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
Where are the amps and how do i by pass them for the stereo
The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
I hope this helps!
Nov 11, 2009 | Car Audio & Video
Hooking up external speakers to Sansui HDLCDVD320
I'm sorry, but the Sansui HDLCDVD320 has no analog audio out jacks. If you have a cable or sat box, etc, you might be able to get audio from their outputs. I hope this helps you.
Dec 14, 2008 | Sansui HDLCDVD320 TV/DVD Combo
Feb 01, 2007 | Sansui RZ-5300AV Receiver
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
