After reconnecting system, Soyo monitor no longer has audio
  • Gerald Priest May 11, 2010
    Have you insured you reconnected the wire between your soundcard and the monitor, also make sure the volume within windows is turned up.
  • 96 Answers
Use PC wizard 2008 and open the hardware and hardware driver for your audio and after searching or locating it find your cd installer and reinstall it or research it from the internet downloads.
Posted on Jan 26, 2010
I cannot hear sound from the monitor, what do I need to do?
you install a application in your pc
application name is " realtek audio driver
Mar 24, 2016 | Soyo Computers & Internet
The problem started with frequent occurances of "white screen." I am not a computer geek by any stretch of the imagination but I was able to get it working several times by rebooting, turning...
Suggest connecting monitor to another computer and confirm defect. If problems reoccurs and cables are confirmed OK replace.
dims-mvjfcvkh3nvffkljjmexfvsy-5-0.jpg Common problem capacitors failing in computers and components.
Soyo 2286 LCD Monitor Repair Tutorial
Jul 04, 2017 | Soyo DYLM2286 Monitor
I have a Soyo MT NI DYLM 2086 and have bought a new computer. Do I need to download anything to insure that I get full screen / maximum clarity from the new computer?
The new computer will determine whether this is needed or not. If the computer is a 32 bit Operating System such as Vista 32-bit or Windows XP 32-bit then there is probably no need for any additional drivers. With some of the newer OS systems it may be needed, but there is little chance you should need to download monitor drivers for any system.
If you find that you are not getting complete clarity with higher resolution, in searching around for drivers for your monitor I have found it to be almost a dead end. I am seeing on the net that many people are finding it impossible to find newer drivers. So the alternate could be that you use some of the windows generic drivers to produce the resolution you are looking for and see if one of them works with your Soyo monitor.
Dec 04, 2010 | Soyo Computers & Internet
My computer has no sound. How do I get a sound driver downloaded?
I will try to locate a driver for you, but please post me back your audio card model (if it is separate) or your motherboard brand / model (if the audio jack is on the motherboard) or your computer model / brand. Also post me back the operating system you use (Windows XP, Vista, Windows 7)
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 22, 2010 | Soyo Computer Inc 17" LCD Monitor, Black
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
My Soyo DYLM1986 won't come on and is clicking inside. I have rebooted the computer, disconnected & reconnected from the CPU & monitor. Can you reccommend anything to help? Cindy
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Soyo DYLM1986 Monitor
Screen won't come on, and it is clicking inside
unplug everything from the computer then reconnect everything help?
Feb 06, 2010 | Soyo DYLM1986 Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
