My Kenmore series 80 top loading washer drains prematurely. Model # 82380100. Is it the fill level pressure switch or the controller? It is a recent development. I have owned the washer for over 25 years. My wall drain is 32 inches off of the floor, and is functioning properly. It seems to do the premature draining the most often on the Regular wash cycle. The tub will fill, the agitation will run for a few minutes, then the agitation will stop, the tub will begin draining. It may drain for 5 to 10 seconds then stop draining and resume the agitation with a lower water level. Occasionally it will do this and pump enough water out that it trips the pressure switch and the tub will begin filling to the water level set at the start of the wash cycle. The wash cycle will then resume. It may do it again before the wash cycle completes or it may finish the wash cycle with no interruptions. I have not noticed the premature draining during the Permanent Press or Delicate wash cycles.
  • mmksp
    mmksp Dec 02, 2012
    I want to add that it does not drain prematurely during the rinse cycle, only during the wash cycle
2 Suggested Answers
SOURCE: Kenmore washer won't stop filling during initial wash cycle
Iam not a expert but I have had that problem you have a presure switch some times called a leveling switch. This telling the washer when to stop filling.On the leveling switch there is a plastic rubber hose this will let you know this is the leveling switch. That would be my guess. Hope this helps have a blessed day.
Posted on Feb 11, 2013
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
My washer wont stop filling up.cold and warm work but it doest know when to stop filling up hot doesn't work at all.please help my water bill was really high this month it a kenmore 80 series...
There is a defect or , malfunction within the Water fill level pressure switch. this switch will cost about 35 dollars and, it should be replaced asap.it has failed.
Replacing the
Water fill level pressure switch, will fix your issue.
Jun 16, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series heavy duty 3 speed
This problem is generally caused by a pressure switch failure. The pressure switch controls when to shut the water inlet valve off at the appropriate level and is located behind the load level or water level selector knob on the operator console. Before assuming, however, that you have a defective switch, read the following link first:
http://www.fixya.com/support/r762094-washer_overflows
In the majority of the problems I have experienced with an overflow condition on a washer, it has been caused by the air hose coming off the pressure switch. Hopefully, this will be the case with your washer and will not require parts. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 won't stop filling.
Kenmore washers
Fill switch
pull off fill knob
remove plastic trims from front face ends of control panel exposing screws
remove phillips head screws from bottom
slide control panel forward & up ~1inch then flip over backwards on top hinges
to remove fill switch
depress lock tab right side where switch body touches back of control plate
rotate counter clockwishe 45-90 deg
withdraw fill switch
remove plastic tube from switch body
Blow any water out, should be empty when washer is empty messes up pressure sensing
refit plastic tube
adjustment screw is 1/8" hex head bolt next to knob shaft
clockwise raise water level
counter clockwise lower water level
can be operated in this open position to check operation, may have to move switch between fill positions to restart fill operation
Nov 27, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
