Question about Gateway DX483101e PC Desktop
My gateway desktop does not recognize any sd/xd cards
MODEL NUMBER ON THE BACK OF THE PC JUST READS GATEWAY 4831 NOTHING ELSE. NO MATTER WHAT KIND OF CARD I INSERT INTO THE SLOTS, NONE OF THEM WILL READ. NOTHING SHOWS UP UNDER "MY COMPUTER" NOTHING ANYWHERE. PLEASE HELP
  • Rick Oppelt
    Rick Oppelt Dec 02, 2012
    I WANT TO ADD THAT I HAVE HAD THIS COMPUTER FOR A COUPLE YEARS. AND THE CARD SLOTS HAVEN'T WORKED FROM DAY 1. I DON'T KNOW WHY I DIDN'T JUST TAKE IT BACK.
  • Gateway Master
  • 5,660 Answers
Either the Card Reader isn't plugged in, or isn't any good.
Repair would be to purchase another Card Reader, but after checking the USB header/s on the motherboard, that the Card Reader is plugged into.
(FOLLOW Anti-Static Precautions)
Or you can use an external Card Reader, and plug it into a USB port,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951865&csid=_61
Your keyboard has a problem too. It's stuck in capital letters.
joecoolvette
Posted on Dec 05, 2012
melnavz
  • 1226 Answers
SOURCE: gateway sb-4100-b won't recognize new memory
REmove all the old memory and replace it by a new memory, you should test memory 1 by 1 .
first install the 1 memory in the first slot. then boot the computer using only 512mb. if this successful. shutdown and insert the second memory, then test again.
note: memory should be:
1. DDR SDRAM
2. the two 512 should be the same brand.
Posted on Dec 28, 2007
  • 30 Answers
SOURCE: Computer not showing anything
Did you check the type of the memory card the motherboard of your computer would support? It may be a DDR1 or DDR2 and also check how much memory your motherboard can hold. You disconnect the memory card and check to see if the computer would turn on.
Posted on May 30, 2008
  • 2692 Answers
SOURCE: Gateway GT5228 PC Desktop
Boot into safe mode and see if you can either roll back the driver restore the computer to the date right before you downloaded it.  the link is for directions on how to boot into safe mode.   Another option , if you have on board graphisc alos is to hook up the monitor to the onboard  turn it on in BIOS and change the driver for the card using the onther graphics.
http://www.pchell.com/support/safemode.shtml
Posted on Jan 28, 2009
HeXx13505
  • 65 Answers
SOURCE: PCI Express slot not working
go into the bios and change the video settings from onboard video to pcie video
Posted on Mar 27, 2009
rasengan79
  • 138 Answers
SOURCE: my Gateway GT5654 desktop just quit in the middle
Based on my experience, the most probable cause of your problem is the RAM. Try Cleaning the RAM first by removing it from the slot, and rub the pins with a pencil eraser. As shown on the image below: 263dfab.jpg
Then re-install it to the motherboard. If problem persist, you may need to replace your RAM.
Note: If you have two RAMs on your pc, might as well clean them both, and then test each RAM to find out if either one of them or both are busted.
Posted on Sep 24, 2009
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
How can I get the card reader to recognize sdhc cards
It's not your card reader, the SDHC mini firmware is dead that's why your reader cannot detect it. Warranty, return it to SanDisk for a new one. Every hardware you plug or attach to a PC or Laptop has what is called a firmware, a mini program that communicates with your PC and Laptop that's how they syst
Dec 30, 2012 | Gateway GT5082 PC Desktop
Can not gt my sd card into the slot do u need a spefic kind
Yes the type of card matters for the slot. If your pc/ laptop is newer and you have never used the slot, then more than likely the dummy plastic piece is still in it. This needs to be removed before you can insert any cards into it. Also, an SD card will only fit an SD slot, there are many other types of cards as well. If your card slot says that it will except SD, XD, miniSD, and so on.....then you can insert the SD card that you have.
Aug 27, 2011 | Computers & Internet
My acer ast180 ua381 does not recognize sd cards over 2 gigs no matter what card reader i use or what micro card i use ( ie 4, 8, 16, 32 gig) and nothing changed after i upgraded to windows from vista.
If you were to log on to the manufacturer's web site, I think you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
The information is normally free of charge.
You need the drivers! Down load the drivers and it should work.
I hope this helps.
Jan 22, 2011 | Acer Aspire (AST180-US340B) PC Desktop
AST135-US3303 has reader for XD, SD, etc but will not recognize my SD card when inserted. The light beside the card comes on but no window appears (XP home)and I cannot get to my data. Card works in...
Quick test for you if you insert the card and you can send a file from you computer say any document and it transfers across and read it back the card and the reader are ok. It will be the file type of the pictures that it at fault most cameras memory cards are of a Raw format and some OS's dont like it. Try a blank SD card if you have one, format it on the computer then insert in camera and see if after you take a few pic you can see the file.
Aug 23, 2010 | Acer Computers & Internet
Gateway windows XP media edition will not recognize sd card
Tell me if it recognizes the USB drive ?
If it does, Try plugging card reader and see if that helps !!
Please let me know the status.
Thanks
Mar 28, 2009 | Computers & Internet
Cisnet card reader
hi, the USB port might be recieveing the power, but the card chip must not be , try cleaning the contacts, or try some other reader to see if that works.. let me know
Jan 04, 2008 | ZT Group Cisnet T2060 Notebook Computer
Gateway DX483101e PC Desktop Logo
163 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
