Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP34 I installed new conversion chips stk392-110 and the conversions is all messed up , does anyone know why i could fix this problem? Do i have to go into the menu on the set ? PLEASE HELP THANKS MIKE
  • Luda315 Jul 17, 2008
    I changed the ic's and the ohm on my tv and it still has a swirl at the top and at the bottom. and the convergence doesn't work. I tried resetting it from the menu but it doesn't move neither vertically nor horizontally...What could I be doing wrong..HELP...
  • 203 Answers
Have you got the cable connected properly and attempted a consumer convergence in the menu? If you've attempted that and are still having the issue there may be other components on the Conv Module that have failed.
Posted on Jun 08, 2007
I have a JVC AV-48WP74 48 in. Rear Projection
Must know basic soldering and have tools like soldering iron,a desoldering pump or desoldering witchs to replaced parts on the tv convergencce board.U have none of these tools devices and never solder bsfore,better hire the tv tech. to do the job.Cost estimate 300-350 for parts and labors.Tries wesite like Tvrepairworld.com,Tvrepairkits.com to buy a whole convergence kit,to do it ur self,if u can?
Jul 25, 2010 | JVC AV-48WP74 48" Rear Projection...
Need Service manual to line up convergence
I went to JVC companies and a page came up and I selected services and I downloaded the manual.
Oct 30, 2008 | JVC AV-48WP74 48" Rear Projection...
Im having green and blue conversion issues on my JVC 48wp34.please help
You need to replace both STK392-110 convergence ICs, you can get replacements at the following link with free installation instructions and free tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Aug 23, 2008 | Televison & Video
Conversion probleme with jvc av-48wp74 i did the set-up but dont want to keep it
you need new convergence ICs STK392-110 ICs and the JVC convergence resistor Kit #1 you can get the parts at the following link with free instructions and free online tech support to help you with the final adjustments after install. Here is the link.
Aug 10, 2008 | Televison & Video
JVC AV-48WP34 convergence issue
Chances are there are other resistors open
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP34
MPOP72 One very important servicing note to remeber with this unit module is: If you remove the rear cover while the power is on or plugged in you will destroy all DVI programing inside the DVI (Digital Input Module). The only way to restore the programming is to send that module to JVC. There is a light sensor inside the TV and when the back is removed with the power on the data is electronically erased from the eprom. First turn off the set and remove power cord, then short pins 1 and 2 on the SB connector of the digital input module. Before the rear panel is insterted into the cabinet remove the short on the SB connector. DO NOT TURN POWER ON until the rear panel is inserted into the cabinet. If you have to work inside the set with power on remove the two cables going to the DVI module. That said, if you merely accessed the front panel and changed the convergence amps, re-installed that board, and cannot seem to restore convergence - then you have a secondary problem, probably one or more of the feed resistors on the amp in that circuit have failed. If everything appears okay and you are able to align convergence in the customer menu then the only last step to storing the setup is to press enter and then exit the convergence menu. If the info is still not being stored you still have a problem on the convergence board and probably with a resistor or two. There are a series of 1.5 and 2.2 ohm resistors 1w on that board. Take-out your trusty DMM and test each one for open condition or change in value and replace any suspected. Good Luck Bill
Jun 08, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP34
If you are in the service mode, pressing the muting button saves the convergence values to memory.
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
