Question about Microsoft Xbox Computers & Internet
How to disable MAC filter - Xbox Microsoft Computers & Internet
  • Microsoft Master
  • 2,072 Answers
From a computer connected to your network. Open a cmd prompt and ype "ipconfig" please note your default gateway address, this is your routers address. Ex. 192.168.0.1 Now open a web browser and enter the gateway address. You should be prompted for a login if you have one set. Enter that and you will be in the router config screen. Navigate to the filtering section, it will probably be under security and disable it. Click Save/Apply. You can now close your browser window. If you have forgotten your password you will need to push the reset button on the back of the router for about 10 seconds and start over configuring it.
Posted on Dec 02, 2012
How to disable MAC filtering
MAC (Multimedia Access Control) addresses are unique sets of codes assigned to electronic devices that identify the devices on a network. MAC filters work by either allowing or denying only specific MAC addresses. MAC filters are a great security measure; however, if your network needs to be open to public or guests, or you're adding and removing devices often, then you should consider turning off MAC filtering.
EditMethod One of Three:
Wireless Routers (Windows)
  1. 1 Open the Command Prompt. You can access it from the Start menu, or by pressing ? Win+R and typing cmd.
  2. 2 Type .ipconfig and press? Enter.
  3. 3 Find your active network connection.There may be several connections listed in the readout, and you may have to scroll up to find your active connection.
  4. 4 Look for the .Default Gatewayentry. This is the address for your router. Write it down.
  5. 5 Open a web browser. You can access your router's configuration page from any web browser as long as your computer is connected to the network.
  6. 6 Enter the .Default Gateway address into the browser's address bar.
  7. 7 Log in with your admin account.Routers are protected with an admin login and password. Check your router's documentation or look up the model online to find the default login information.
    • If you can't figure out how to log in to your router, you can reset it by pressing and holding the Reset button on the back for about 30 seconds. After the router restarts, you will be able to log in with the default admin information.
    • Most default logins use "admin" as the username, and then "admin", "password", or a blank field as the password.
  8. 8 Open the "Advanced" section and look for "MAC Filtering", "Access Control", or something similar. Actually defining where the "MAC Filtering" section is located is very difficult, as the location and labeling is different for every router. Generally, you can find the "MAC Filtering" or "Access Control" settings in the "Advanced" section, though it may also be found in the "Security" or "Wireless Settings" sections.
    • Not all routers use MAC address filtering. Some router's limit access based on static IP addresses assigned to each device.
  9. 9 Disable MAC filtering. Again, the wording and location will vary depending on the router, but you will generally be able to select a "Disable" option to turn off MAC filtering.
    • This may be a checkbox, a button or a selection that you can make.
  10. 10 Save your changes. Click the "Apply" or "Save" button to save your changes to the router settings. Your router will apply the changes, which may take a few moments.
    • If you are configuring your router over a wireless connection, you may be logged out when settings changes are saved.
Jun 08, 2014 | Belkin F5D7234-4 Router
I need to add a mac address to my router..so far not working
Open the setup page of the router and go to wireless tab. Click Wireless MAC filter sub tab. If wireless MAC filter is enabled then disable it. This option is always disabled by default. I think the wireless network might be the issue. If your wireless network is secured then make sure that you are entering the correct network key WEP / WPA .
Dec 01, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Hi, MY Acer aspire wont connect to my network. I have enter the wep key and when i try to conect it fails and says not connected. WHY?
YOUR WIRELESS ROUTER IS PROTECTED WITH MAC FILTERING
FIRST TRY TO DISABLE MAC FILTER THEN TRY AGAIN
PCCLINIC INDIA
Aug 10, 2011 | Acer Aspire One PC Notebook
My netgear router have strong signal but computer says dont get response from the router
There could be another security settings that are enabled n the router. There is a possibility that the MAC filtering is enabled. You have to disable the MAC filtering.
Apr 06, 2011 | NetGear Computers & Internet
I have Kindle 3 WiFi and cannot connect to my Linksys WRT54GS in my home. How do I change the setting to allow MAC access? Thanks!
Hi, the MAC address filtering settings can be accessed by logging into your router's configuration software (type 192.168.1.1 into your web browser and hit Enter, then type in your username and password) and going to the Wireless tab and beneath that, Wireless MAC Filter. You can either choose Disable to turn the MAC filter off completely, or you can choose Edit MAC Filter List and add your Kindle's MAC address to the list of approved devices.
Jan 19, 2011 | Amazon Kindle 3G
How do you disable the MAC address filtering on a Belkin router F5D7234-4 v4 (01)?
open the belkin outer interface by following this link below...
http://www.fixya.com/support/r4724899-configure_belkin_routers_without_install
goto "Mac address control" on the left side below "wireless" ...
Delete the Mac address or disable the feature and apply changes... Thats it...! u r done....!
Jan 03, 2011 | Belkin F5D7234-4 Router
Can not use my wii online wireless
Make sure that you are entering your password correctly into the wii menu. If you are still havin trouble, try disable the your wirelss security to see if you can get on at all. If that then you have a Mac Address filter turn on your wirless you will have to turn it off. Once you find the mac address filter for the wii, then you can enter that into the mac address filtering and it should work.
Sep 29, 2009 | Computers & Internet
MAC ADDRESS FILTERING MAY BE ENABLED ON MY WIRELESS ROUTER?
should be an option in the console (in browser go to 192.168.0.1 or 192.168.1.1, etc)
MAC Filtering just means that you can set up a set of MAC addresses (Machine Address) of units you want to be able to access your network. If you didnt set the MAC of a unit it will not be able to join the network. So mac filtering is a way to limit connection with your network.
For future assistance please visit http://www.hoosierpcrepair.com
Jun 22, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Disable internet access
Access your router Setup page
Open internet explorer go to http://192.168.1.1 (default) username: admin (default) password: "leave it blank" (default)
Go to Security go to Filter
if you know that Ipaddress of the computer you want to block for example 192.168.1.10
You can create up to five different IP Address Range filters   Users who have  filtered  IP addresses will not be able  to  access the  Internet at all   If you only want to filter one  IP  address instead of a range of IP addresses, enter the same  value into both fields  For instance, if you wish to filter the  PC with  the  IP  address of 192 168 1 5, enter 5  into both  fields on one line: 192 168 1 5 ~ 192 168 1 5
if you know the MAC address of the computer click the Edit MAC Filter Setting and input the MAC address you want to block.
blocking by MAC address is the most effective solution to block a computer... while blocking by ip address will be easily bypass by changing the ip add of the pc
then saved your settings and reboot..
Jan 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I tried to set up HP Photosmart C4580 printer/scanner/copier with my Airport Extreme. However it is not connecting to the Airport Extreme. Diagnostic check recommends temporariiy disabling the Mac Address...
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
Dec 02, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
