Question about White Sewing 979
The feeder plate isn't working. how do I fix?
The feeder moves forward and back but does not rise up to move material.
  • White Sewing Master
  • 7,365 Answers
Here is a link for a free manual see if it has the information in it
about the feed dogs, some machine have a lever to adjust the
feeddogs and some don't
http://www.singerco.com/uploads/download/864_white-970,972,979-x-.pdf
Posted on Dec 02, 2012
2 Suggested Answers
SOURCE: teeth do not move material forward when sewing
the problem is the feed dog is in the wrong position,, in the operation manual it should tell where the feed dog is on that sewing machine, & what position it's suppose to be in to sew normally
Posted on Aug 01, 2010
I have a new ruby sewing machine the material will not pass under the foot. The needle just goes up and down in one spot
Make sure the stitch length is set high enough to actually move the fabric. Also check that the feed dogs are actually moving forward and backward when stitching (they should move from front to back, then drop below the needle plate and move to the front, where they rise again,)..
Feb 02, 2018 | Sewing Machines
Thank you for the rapid response. It's a Husqv 1070 model. I have cleaned out the lint under the pressure foot and plate. The feed teeth are still not feeding the fabric. Any thoughts?
Are the feed dogs actually functioning? Are they dropped below the needle plate, move forward, then up, and move toward the back while above the needle plate? If so, then they are working properly. If they are not rising above the needle plate, then they could be stuck in the lowered position (check that it is not set for darning). If they are not moving at all, then something may be disconnected or they are gummed up from old oil that has dried. If they are moving, but not grabbing the fabric, then the teeth could be worn down.
Jan 30, 2017 | Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
How can I get the material to move forward when machine operating?
the feed dogs are not working, they hold the fabric against the
presser foot, so the fabric is moved forward,they are in the needle
plate, they should be seen & felt in the center of the needle plate.
Sep 04, 2012 | Sewing Machines
I cant get the material feeder to come up so that the material can slide
Make sure feed dogs (teeth in needle plate beneath needle) are showing. Flip switch to UP position to "feed" fabric. Sometimes control fir this located on back of machine lower left side and " hidden" by your extension table, so remove that table and you'll find the switch! Jimmy
Apr 07, 2012 | Singer 3116 Simple
Bernina 240, won't complete the buttonhole
Double check the instructions and if there is still an issue, call the Bernina dealer and tell them what is wrong.
Ask if someone will be available to look at the machine when you come in .... you need one-on-one assistance.
Mar 07, 2010 | Bernina Sewing Machines
I have an older 1998 portable Bernina with feeder problems.
Maybe just working that bullet shaped part will get it going. If it's a 930, you need to turn the handwheel to make the dogs get back into 'operational mode' after you move the knob.
Sometimes the mechanism is stuck behind the knob. Don't force the knob. It's possible to take the motor casing off and work it loose. Use TriFlow lubricant (small black bottle Sherwin-Williams) and leave for a while. Push gently with a pencil. Whatever you do, don't whack it with a hammer, like some folks say. It likely needs to move in the other direction (if it's stuck in 'regular' mode) i.e. towards the needle end.
Jan 18, 2009 | Bernina Sewing Machines
Material will not feed across pressure plate of my new home model sx 2122 sewing machine
This machine has a pressure regulator on the left side.You should look to see that it is not loosened. When you lift up on the presser foot it should have resistance.
Then look at the feed dogs to see that they are moving, Set the stitch length at 4 and turn the hand wheel. The teeth should move towards the back of the machine. They should also be slightly above the needle plate as they go back and below the surface of the plate as they come forward.
If they don't rise above the plate , remove the needle plate and clean between the slots of the teeth.
sewman7
Jul 01, 2008 | New Home 2014LE Mechanical Sewing Machine
Kenmore sewing machine # 385.17626 feed dogs not advancing fabric. Appear to move up and down, but not forward to back.
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Jun 21, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
White Sewing 979 Logo
79 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
