Question about Motorola iTECH iQfive iQplus -VISAR Compatible Two Way Adapters 2-Way Radio
Visar gone dead
Hi, I have re-cased a Visar and it worked fine but I disconneted the RF bord from the logic bord for several hours to work on a second Visar and the first one did not work when I reasembled it. The second one worked fine with the first ones logic bord but again stoped working when I did not reconnect it after a few hours. Any ideas would help! Thanks
    Brigadier General:
  • 8,619 Answers
Hi1
Please check all the connections inside the case and also the connections of the battery. Check if there are any loose connections on the board which are causing the battery to drain very fast.
Please ask for further clarifications.
Thanks
Rylee
Posted on Mar 11, 2009
  • 11,896 Answers
The boards capacitors still continue to store power when battery/power source is removed. This holds it's internal memory. Once the power has completely ran out, the memory is gone and than you will need to either find reset button, leave battery source plugged in for a couple hours to recharge the capacitors, or you will have to have them taken in for firmware upgrade.
Icom ic 7600 rf issue
it is just because your cable is loose, try it after tightning it up
Jun 05, 2012 | Icom IC-7600 HF/6 Transceiver
Volvo v40 alarm will not turn off with remote.How can I turn it off manually.It is not the fob battery.Car will start with the key but alarm keeps sounding.Neighbours are unimpressed.Have tried...
In some cases you may need to unlock the door but leave the key turned to the unlock position for a few seconds. Aside from that your RF receiver for the signal from the keyless could be at fault. Hope that helps.
Aug 05, 2011 | 2007 Volvo V40
Other letters on my keyboard doesn't work..
Well could be that the keys that don't work might be dirty try using a compressed can of air and spray the keyboard also turn it upside down and shake might be dust clogging it or you might have to reconnect the keyboard so you might have open it up. Worst case the keys probably crapped out
Mar 01, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
Watching TV on my SONY FDL-310!
Any of the digital to analog converters should work. Connect the converter RF OUT to a COAX cable, connect the wire in the center of the COAX cable to the Sony antenna with an alligator clip type patch cord. Tune the sony to the proper channel (3 or 4). Voila!
Jun 24, 2009 | Sony Watchman FDL-22 2.2 in. Television
Dead RF-out on SNES and vertical lines on Multi-out
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Apr 19, 2009 | Nintendo Super NES Console
I just got 2 Motorola Visar and i'm looking for an owner's manual to learn using them. Can you help me?
The radios have to be programmed by a RSS (Radio Service Software) and a RIB (Radio Interface Box) is needed. You can learn more about hat by going to www.batlabs.com additionally, the VISAR page is http://www.batlabs.com/visar.html
If you want to buy a RIB you can get the software and programming info at http://www.ham.dmz.ro/motorola/visar.php
Mar 21, 2009 | Motorola iTECH iQfive iQplus -VISAR...
Drive not recognized
there is a problem with the power supply of the hdd please let some technician check it if its giving the perfect output of power if yes PLEASE CHECK THE HDD IS WORKING FINE BY DIRECTLY CONNECTING THE HDD BY REMOVING FROM THE CASING IF IS FINE U SHOULD CHANGE THE HDD CASING OR REPIAR THE CIRCUIT BORD INSIDE THE CASE ...
IT HAS A RESISTANT SHORT ....
GOOD LUCK
Jan 04, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
CREATIVE ZEN GONE HAYWIRE
sounds like it might be either a bad firmware driver, which can be erased and reinstalled via the USB connection to your computer and a download from creative. Or the battery has gone bad, in which case you have to have it sent to creative for Repair.
Jun 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Nov 28, 2007 | Televison & Video
Motorola iTECH iQfive iQplus -VISAR Compatible Two Way Adapters 2-Way Radio Logo
46 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Iron
Iron
OBHighflyer
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
