Question about Zoom 4506 Router
Cant find the wps code for the zoom 4506 router to set up a network
Trying to set up a network useing a zoom 4506 router, all i have for internet is a 3g hotspot devise. i just got a wireless printer and would like to be able to use it in that way
  • Bridget Gille Dec 02, 2012
    when i hit the wps button on the side of my router, my printer will connect but then my computer asks for a wps code. my son helped me with it and said that the code sould be on the side or bottom of the router and it is not their. the router also needs no software
  • 3,606 Answers
Hello download the user guide here:
http://www.zoomtel.com/techsupport/mobile_broadband/mobile_broadband_4506.shtml
Here is the other model:
http://www.zoomtel.com/techsupport/mobile_broadband/4506BG.html
You have to connect a lan cable (if there) between the printer and the modem and redo the printer installation again
so your pc can see the printer.
Good luck
Posted on Dec 03, 2012
Benimur
  • 6966 Answers
SOURCE: Zoom X6 wireless router
Hi, With or without the firmware update, the wireless should work and be indicated with the WLAN led. Have you done an update? Have you tried a hard reset? Most routers would require a reset to default after a firmware update. Pls be reminded that when you do a hard reset, all configuration would be lost, better log them down or do a backup. Alternately, you can check your router's web based configuration manager, apparently, there is an enable/disable feature/selection for the WLAN. Verify that is set to enable. Hope this be of help/idea. Post back how things turned out or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE: Zoom x6 model 5590 wireless router
DNS has nothing to do with DHCP kakee.
I have a Zoom X6, add each IP separately and it should be ok.
Posted on Aug 21, 2008
kakee
  • 1269 Answers
SOURCE: Router works but internet to computer does not.
Your pc might be using a static IP address. Make sure its on automatic. Go to Control Panel, Network Connections. Right-click on Local Area Connection and click Properties. Look for Internet Protocol TCP/IP and double click it. Select Obtain an IP Address Automatically and Obtain DNS Servers Automatically. Click OK all the way out. Also disable any firewall you have like Norton Firewall, McAffe, Zone Alarm and the likes.
Posted on Jun 22, 2009
govinda123
  • 2263 Answers
SOURCE: No Internet Connection with Zoom 4501 & HUAWEI K3520 3G Dongle
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Posted on Dec 19, 2009
Geekman
  • 32281 Answers
SOURCE: device asks for passphrase or pin, what is this,(zoom 3g router)
The passphrase is used to generate the encryption code in the router's wireless configuration.
For instructions to configure the router's wireless settings ant to configure the wireless card in the laptop/computer - please click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Jan 03, 2010
How do I set up my moto e4 by wps push button?
Usually you select the wifi network, tap Connect and then you're prompted for the password. I've never tried it, but if you pressed WPS on the router just before tapping Connect, maybe WPS would work.
May 15, 2018 | Option Computers & Internet
Where is the wps number on a hp compaq presario CQ57
The wps button is on your router, not the laptop.
Sep 23, 2017 | HP Computers & Internet
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
No lights showing
I would turn both the modem and the router off. Then turn the modem on and let it cycle up for a minute or two. Then turn the router on and let it cycle up. The router always has to boot up after the modem since it is dependent on the modem.
If it does not work, then either your router is bad or your internet service has been interrupted.
Jun 05, 2012 | Zoom 4506 Router
Router has to be real close (less than 1m) in order to function over WiFi. Tried every possible settings combination without luck. Any clue?
Sounds to like there is interference. Do you have a cordless phone or any other device operating in the 2.4GHz frequency range?
Mar 05, 2011 | Zoom 4506 Router
When i try to set up my new 3g mobile bbroadband wireless-n router the computer ask me for a pin number that sopposed to be in the back of the router and already try all the numbers that i can found and it...
This is a common issue with Windows 7. To get around this issue, try the following steps.
  • Click the Network icon, located on the right of the taskbar near the time. It should look like a computer monitor.
  • Locate the Wireless network you want to connect to and highlight it and click connect.
  • At this point you should be given two options: "Setup the Network connection now" or "No, connect to the network anyhow.
You want to select the option for "No, connect to the network anyhow"
  • This will bypass the requirement of a PIN, which is not supplied with these routers.
asked for PIN when connecting to wireless network What should do
Feb 23, 2018 | Zoom 4506 Router
I can't set up wireless internet at home. It's asking me for a username and password that I don't know and can't bypass. Any help would be greatly appreciated!
Its asking for the username because in ur router, wi-fi protected set up(WPS) is enabled. Acsess the router's set up page using its default IP, and disable the WPS option, it wont ask for username and password anumore.
Aug 12, 2010 | Efficient Networks Computers & Internet
I have two laptops and want to set up a wireless network. I have the wireless set up but it isn't secure. When I go in to the Homegroups page it asks me for a 4 or 8 digit PIN number found on the router....
If you don't know it, you won't be able to automate your Wifi Protected Setup (WPS). The pin is a very specific way to prevent yourself from always having to remember codes, keys, passphrases, etc. Without it, its like saying that you want to to connect to Bank of America, and that it's just okay because you want it to happen.
The following is taken from the ESR-9753 manual:
- Wi-Fi Protected Setup (WPS)
WPS is the simplest way to establish a connection between the wireless clients
and the wireless router. You don’t have to select the encryption mode and fill in a
long encryption passphrase every time when you try to setup a wireless
connection. You only need to press a button on both wireless client and wireless
router, and the WPS will do the rest for you.
The wireless router supports two types of WPS: WPS via Push Button and
WPS via PIN code. If you want to use the Push Button, you have to push a
specific button on the wireless client or in the utility of the wireless client to start
the WPS mode, and switch the wireless router to WPS mode. You can simply
push the WPS button of the wireless router, or click the ‘Start to Process’ button
in the web configuration interface. If you want to use the PIN code, you have to
know the PIN code of the wireless client and switch it to WPS mode, then fill-in
the PIN code of the wireless client through the web configuration interface of the
wireless router.
Jun 28, 2010 | EnGenius ESR-9753 SOHO Wireless Broadband...
I am having problems with setting up my printer (Epson TX710W) to run remotely from my router. When I attempt to setup the router it wants me to use it for internet connection but I am running my internet...
Hi Robert_fl657,
For any printer to run on the network (wired or wiireless), aside from just a router, you will need a print server. Now, since this printer has wireless capabilities, i am going to assume that you might have a wireless prinet server built in (WPS). If your wireless router does not have that function, i suggest you buy a wireless print server to accomodate the printer that you would want to hook up.
Possible Solution 1: Sync wireless printer with WPS button on wireless router
1. Try and locate the WPS button (if any) on the wireless router.
2. Once located, go to the network options on the wireless printer and select set up by WPS.
3. Once you have selected that option, the printer should be in a seeking mode. Select and hold the WPS Button down on the wireless router.
4. If all goes well, you should have established connectivity with the wireless router.
I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
Regards,
Technomancer
Apr 04, 2010 | NetGear DG834G Router
Zoom 4506 Router Logo
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
