Question about Shuttle XPC PC Desktop
My shuttle when i turn it on everything sounds fine then the screen goes blank then a message pops up on screen that says signal out of range h:95.4khz v:60.ohz mode should be below 1280 x 1024 75 hz but i cant back out of screen to fix it im guessing its got to do with resillution ive tried to unplug it but that didnt work please help
  • 2,878 Answers
You are right. It is the resolution that was set too high. This can be easily fixed in Windows by booting into Safe Mode and lowering it.
Posted on Dec 05, 2012
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
Screen goes blank and message comes up saying "input signal out of range"
When does the screen go blank? Also what do you have plugged into it this most likely just because your input signal may be set at to high a resolution or frequency. Once I have more information I can assist you further.
Thanks,
Lee
Aug 11, 2009 | LG Flatron L1515S 15" LCD Monitor
Unsupported video signal
It is possible that Jewelquest changes the screen resolution to one that is not supported by the TV. I am not familiar with Jewelquest, but the typical reason for the unsupported message is a resolution outside of the supported range. The supported resolutions should be listed in the owner's manual. Dan
Jun 12, 2009 | Toshiba REGZA 47HL167 TV
Screen goes blank at first try. Works after 1-2 tries.
this may be your inverter going bad. Inverter is the board(s) on the side of your TV that powers up your screen.
May 16, 2009 | Vizio L37 Television
Getting out of range on my ViewSonic Monitor
try to check the memory. sure its on the board.
May 05, 2009 | Computers & Internet
Monitor not supported
Well the monitor not being support is not the issue. the issue is the video card cannot produce a signal that is supported for the monitor. Its doing this to let you know also to lower your resolution because the monitor will pop if the resolutions is to high. the monitor itself does not matter if you had Vista as lond as the monitor agree with the signal your cool if it don't it will do this. Try lowing the res using another monitor then put the orginal back on and you should be good.
Thanks
Apr 24, 2009 | HP dc7700 PC Desktop
Signal out of range
If your PC is working with a different monitor then your monitor is going bad.
Mar 28, 2009 | Computers & Internet
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Shuttle XPC PC Desktop Logo
51 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
