Question about John Deere Garden
John deere 318 adjust parking brake - John Deere Garden
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Posted on May 19, 2009
  • 69 Answers
SOURCE: HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS
Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
woobie dog
  • 1273 Answers
SOURCE: 318 jOHN dEERE WILL NOT CHARGE BATTERY.
Hello, W/D here.
The best place to start is to clean the terminals on the wires and lugs at the solenoid and battery. Shiney and bright is the rule.
Please repost or respond to this post so we can try more if necessary.
Best regards, --W/D--
Posted on Aug 16, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 4210 brakes are locked up
On both sides of trans housing just in front of axles is where brake shafts go into trans.To fix this you have to spray alot of lube between shaft and housing while trying to rotate shaft.This may take hours to free up and also check for the return springs to still be hooked up to lower roll bar frame.I have seen this alot in the 4000 series tractors.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
I have a john deere 2025r need to adjust brakes how do u do it
I found your owner's manual but it doesn't state how to adjust the brakes.You have a brake rod connected to your brake lever,it has a adjuster nut on it that you need to adjust for your brakes to tighten up to make it stop.John Deere is real secretive on how to do repairs.Just follow brake lever where you push brakes with your foot and you will find,will have two nuts,one adjustes and the others locks it in.You will need two wrenches to do this.
Aug 13, 2017 | John Deere Garden
Is there a hand brake adjustment on a 855D
John Deere Gator XUV 4x4 855D adjusting handbrake ...
www.fixya.com/.../adjusting_handbrake/.../john_deere/gator_xuv_4x4_85...
John Deere Gator XUV 4x4 855D atvs adjusting handbrake unsolved issues. Ask your John Deere Gator XUV 4x4 855D questions. Get free help from atv ...
  1. John Deere Brake Adjustment‎
    Adfixya.com/John+Deere+Brake+Adjustment‎Troubleshooting Tips
  2. Free Manuals
  3. Instant Solutions
  4. Instant Answers
  5. John Deere Brake Adjustment‎
Jan 17, 2016 | John Deere 2012 Gator XUV 4x4 855D
How to adjust parking brake on the John Deere X320 lawn tractor mower?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 21, 2015 | John Deere Garden
John Deere 262 parking brake won't disengage. Stuck in neutral and won't move
Marti: According to GreenTractorTalk.com, T Mo said: "A couple of things come to mind, first is the brake sticking. Second is the brake linkage needing adjusting, therefore not releasing the brake. Thirdly, the linkage for the gears itself." This YouTube video shows brakes but not for your model: https://www.youtube.com/watch?v=Ce_d9-2c7wI
May 25, 2015 | John Deere Garden
Got new brakes and now the hubs won't turn
You need to adjust the slack adjusters
Jan 31, 2013 | John Deere Garden
Need a electrical diagram for John Deere 318
You might want to post this question in a different section. This is the computer section...
Aug 17, 2012 | John Deere Technical Service Repair Manual...
I have a john deere 6810. The parking lock will not hold the tractor stationary when under load. I have not been using the handbrake as it does not work. My question is should the parking lock be used...
hello, parking brake adjustment,,if you look under the tractor behind the right wheel next to the trans. you will see a round disk with a small shoe,turn that in to adjust brake,hope this helps,,
Feb 22, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
There is no parking brake, and "park" does not hold. it is a 1990 cruise air lll on a john deere chassis with a ford 460 engine.
The parking brake is activated by the shift lever. There is no parking paw in the transmission on these John Deere Chassis motor homes. The parking brake is the type that works a brake on the drive shaft. I ran into the same problem and just put a line lock on the brake line.
Sep 01, 2010 | Ford E-350 Super Duty Cars & Trucks
Garden Logo
644 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
