Question about GE DVLR223 Dryers
DRYER WON'T START WHEN START BUTTON IS PRESSED.
  • GE Master
  • 8,220 Answers
The fuse is located on the heater element which is bolted to the back wall behind the drum.
I have several home movies and repair pix on my DIY blogpage:
PAW PAWs DIY GE HOTPOINT DRYER Repair page
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 02, 2012
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Start switch hums, does not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: unit won't start when start button is pressed.
507
is the thermal limit if open due to lint or other problems the dryer will not run.
Of course it could very well be a broken door switch.
I recently worked on a Hotpoint dryer that was eating up clothing.
I took some photos. Hotpoint dryer revamp
Posted on Aug 17, 2011
richroth
  • 9472 Answers
SOURCE: GE Dryer GFDN110ELWW hums loudly and won't start
The start capacitor is built into the motor and you will need to replace the motor. Here is the motor if you should need it.
Posted on Nov 24, 2012
Series 90 model 11050902990 dryer won't start
That model number is a washer.
Dec 01, 2012 | Dryers
Nov 24, 2012 | GE GFDN110ELWW Electric Dryer
Drum is having trouble turning
unplug the dryer before you start ,check roller & pulley or install dryer kit
Oct 18, 2017 | Kenmore 72972 Gas Dryer
Dryer won't stay on when let go of start button.
One of two things is wrong. Either the start switch has gone bad or the start winding in the motor is failing to switch over to the run winding. You'll need to get a multimeter and before starting unplug the dryer. Once thats done, get behind it, remove the back cover to the control panal and disconnect the two wires that are connected to the start button. With your meter set for checking continuity, place a meter lead on start button pins where the wires were connected, one lead on each side.With leads in place have someone press the start button, if continuity shows when pressed and stops when its not, the button is good and the motor is bad. Personally, I think the motor winding has burnt, and the motor should be replace, but I also think that the start button should be changed as well because its in direct series with the motor, and could have taken damage that may not show up until further down the road, plus its an inexpensive part.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Kenmore Dryers
Unit won't start when start button is pressed.
507
Aug 17, 2011 | GE DVLR223 Dryers
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
Hi my dryer is not heating, when I pressed the start button it sparked around the control knob and tripped the breaker and now it won't heat. could it be a fuse or the heating element themodel # is ...
Look at the start button first it might have burn out in the back or look at the capasitor on the motor, other wise it will more than likely be the timer or the motor.
Jun 07, 2011 | Frigidaire Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
GE DVLR223 Dryers Logo
314 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
